Transmission fluid drained & refilled... NOW LEAKING! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2007, 10:58 PM   #1 (permalink)
View HarrisH's Photo Gallery
I just had a simple drain & refill done at 74K miles on an L4 2002 Camry. The fluid wasn't in very good condition so I purchased 4 quarts of T4 OEM Toyota Trans. Fluid.
I went to my mechanic who did a simple drain & refill. I drove the car a little bit and brought it back home and it was fine. I drove it tonight and noticed quite a large pool of trans. fluid.
Jacking up the car I saw it was leaking drops in 4-5 second intervals directly from the drain plug.
I don't have the tool to tighten it. Should I tighten the drain plug or is there a specific gasket or some other procedure that needs to be done in order to rectify the problem?
HarrisH is offline   Reply With Quote
Old 07-17-2007, 11:04 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Have you checked the fluid level?
The drain plug is 10mm allen or hex.
2007 Camry 2.4L 5M
Old 07-17-2007, 11:09 PM   #3 (permalink)
Yeah I'm going to go back to the mechanic tomorrow.
But do you think it might be leaking because I took out the old fluid and put in the new?
Is there a gasket for that plug?
Old 07-17-2007, 11:23 PM   #4 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
yea im thinking he didnt tighten it. But the thing that says it shouldnt be changed is pretty weird. our camry has 90km (56mi) and the fluid was really dark brown and smelt bad. kinda glad we changed it and there is no problems happening.
CamrySExxx is offline   Reply With Quote
Old 07-18-2007, 01:32 AM   #5 (permalink)
If it's loose enough to drip, personally I don't even want to drive it for fear of the plug vibrating off.
2007 Camry 2.4L 5M
Old 07-18-2007, 02:31 AM   #6 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Use a scredriver os something to tighten enough to get to mechanic or parts store to buy a 10 mm wrench? Check it. It should have a gasket underneith but is is likely not tight. Dpont't drive very far this way.
gdanaher is offline   Reply With Quote
Old 07-18-2007, 05:43 AM   #7 (permalink)
yeuemhoai's Avatar
View yeuemhoai's Photo Gallery
Yes there is metal gasket, maybe the mechanic left it off.
'07CamryLEV6|Whyt|V4|EF|Mudguards|All-weatherMats|LipSpoiler|Tinted|3MProtector|LEDInterior|SERims|Xtreme5000K| LEDTaillights...
'01LexusRX300|PearlWhyt...
'96CamryLEV6CollectorEd.|PearlWhyt...
yeuemhoai is offline   Reply With Quote
Old 07-18-2007, 09:00 AM   #8 (permalink)
I got the crush washer replaced and the plug retightened. I'm going to cross my fingers now.
Old 07-18-2007, 12:36 PM   #9 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
Go kick you "mechanic" in the no-no area.
Then get a "technician" to work on your car in the future. Automobiles are too expensive not to have a professional work on them.
The new transmission fluid burns up just like the old stuff. I don't believe in Toyota's extended life transmission fluid. I saw alot of cars with brown/burned fluid when I worked for Toyota. Inspect if frequently and change if it gets discolored. If it gets brown, flush it but don't use any additives when you do so. Just flush it with fresh fluid.
It seems that the cars that were affected the most were used for alot of in town driving.
My fluid still looks like new.
2006 Camry LE Special Edition
Old 07-18-2007, 01:17 PM   #10 (permalink)
View marc780's Photo Gallery
whats more i'd never let that meatball put his hands on my car again if i were you
Old 07-18-2007, 01:29 PM   #11 (permalink)
He reused the original washer... are we not allowed to use them again?
Old 07-18-2007, 01:29 PM   #12 (permalink)
Sorry, what I meant was when it was leaking yesterday he re-used the original washer. I now got him a new one.
But are the crush washers to be replaced after each and every drain & refill?
power steering fluid colour!? wtf 95 COROLLA Archived Corolla threads 14 06-02-2009 10:18 AM
Tranny Oil Xlerator 1st Generation (1995.5–2004) 3 03-19-2007 05:02 PM
A little bit a transmission fluid is leaking from my 92 MR2 Turbo? Zer05 MR2 Forum 3 07-09-2004 09:02 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
my power steering fluid is leaking mkII Camry & Solara Lounge 1 01-09-2003 08:23 PM
