2002 camry le won't turn over - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2007, 12:56 PM   #1 (permalink)
View silvia_s14's Photo Gallery
Gen5 2002 camry le won't turn over
i have a 2002 camry le with 178,742 miles. so today i go to a local denny's to have some grub. i come out to my car and it won't turn over. check the batt cables and messed w/starter still nothing. i have a 1/2 tank so i know it's not that. i turn the key and all my seat belt, oil, and engine lights come on. just won't turn over. so i have it towed home, take the starter out take it to autozone where they tested it and say it's no good. i take it to kragen and they test it three times and 3 times it passes as good starter. the guy at auto zone was new there so i don't think he tested it right. the kragen guy said it could be my batt but it's a 1 1/2 old. i don't think it could be that.
please help, this is my only car and i realy need it right now. thanks
silvia_s14 is offline   Reply With Quote
Old 07-26-2007, 01:24 PM   #2 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
Find somebody who can give you a jump start.
If it starts, go to Kragen (let the car run) and ask them to test your battery and alternator.
If your battery and alternator test OK you should troubleshoot you ignition system.
By the way, did you check fuses?
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 07-26-2007, 02:10 PM   #3 (permalink)
thanks for replying. i checked the fuses under the hood and inside the car they look good. won't be able to check the batt or jump it tell my bro gets off work around 430 or 500. but will check and get back to ya. alternator was just replaced not to long ago so it shouldnt be that. thanks for the help. please any other ideas. thanks again
Old 07-26-2007, 03:47 PM   #4 (permalink)
Gameroom cash: $303755
It could be the starter's solenoid contacts. To test this give the starter a rap with a hammer or a small wrench. Give it a good tap, but son't try to crack the thing. Now try to start it or have someone hold the key in the start position and you go out and tap the starter. If the starter now turns, you have identified the starter solenoid contact problem. This would explain why it tests good at one time and tests bad another. The starter solenoid contact problem can be very intermittant. Do a search for "starter contacts" and read up on the problem.
Mike
Old 07-26-2007, 04:16 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
What does having a half tank have to do with the vehicle not turning over? It wouldn't matter it you didn't have any gas it all. It would have to crank first and fuel has nothing to do with that.
Personally, I think you should have someone that knows at least the basics check the car for you.
The battery and connections is the first thing that you test.
Get a manual and learn how to properly diagnose problems.
You're jumping around for no reason at all. Diagnosing that condition takes a few minutes at most.
GET A REPAIR MANUAL OR CHECK OUT THE ONLINE MANUAL.
2006 Camry LE Special Edition
Old 07-26-2007, 04:32 PM   #6 (permalink)
["I]What does having a half tank have to do with the vehicle not turning over? It wouldn't matter it you didn't have any gas it all. It would have to crank first and fuel has nothing to do with that[/I]."
I was thinking about that too.
Mike
Old 07-26-2007, 04:48 PM   #7 (permalink)
i know it has nothing to do with that but i posted this in other forums and i got stupid answers like alternator , does it have gas. so i just put that in so i wouldnt get that answer on this forum..
i'm not jumping around but i am a little ? right now. i sent it out to toyota said the car should be done friday. well thanks i guess for the help
Old 07-26-2007, 05:20 PM   #8 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
If you turn the key to start and the idiot lights dim out badly then the likely culprit is the battery. You need some basic tools like a volt meter and you need to know how to use them. Just sitting, the battery should show in the ballpark of 13.5-14 volts. If it's closer to 12 volts then it might be bad. The starter solenoid might be bad and at this mileage I would highly suspect it. Since you have no trouble checking skills I would highly suggest that you take it to the local mechanic and have them diagnose the problem. This one is very basic and not at all rocket science.
gdanaher is offline   Reply With Quote
Old 07-27-2007, 07:33 AM   #9 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
ciclk:
http://www.cardomain.com/ride/2034953/11
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 07-27-2007, 10:14 AM   #10 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Isn't it 14 volts with the car on? I could be wrong, but I thought it was around 11 volts just sitting.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 07-27-2007, 01:43 PM   #11 (permalink)
TRD VVTi's Avatar
Gen5
You're right but the battery should still hold 12 volts when the vehicle is off.
Voltage isn't really an accurate way to test a battery or an alternator.
Amps is where it's at. Putting the battery and charging system under load is the proper way to test each.
Old 07-27-2007, 02:44 PM   #12 (permalink)
i got the car running again and it turns out the guys at kragen were wrong. toyota tested the car and tells me the starter is no good. so i purchase one from them brand new 220.00 and installed it myself. took about 30min and was on my way home. thanks for the help guys. i do have a volt meter but my batt tested good and the alternator was good to. stupid kragen
Old 07-27-2007, 04:23 PM   #13 (permalink)
TRD VVTi's Avatar
Gen5
I'm glad you got it fixed reasonably.
You can't accurately test an alternator or a battery with a voltmeter. You can only perform a preliminary voltage check.
Old 07-29-2007, 02:02 PM   #14 (permalink)
Resident Chemist
View Brian R.'s Photo Gallery
Mike was probably correct in that it was your solenoid contacts. You could have replaced them for realy cheap if you wanted to take the time.
Brian R. is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
2002 Camry LE - How to remove hubcaps infamda 5th & 6th Generation (2002-2006 & 2007-2011) 11 01-28-2007 09:23 AM
When to do a tuneup on 2002 Camry LE V6? 2002Camry 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-28-2006 07:36 PM
Speaker Suggestions for 2002 Camry LE V6 2002Camry Audio, Video, and Security - Tech 4 02-25-2005 12:35 PM
92-96 Camry LE V6 suspension- supposed to be firmer than 4-cylinder? 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 6 09-20-2003 02:33 PM
