Change automatic door locks function - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2007, 03:46 PM   #1 (permalink)
View Agent WD-40's Photo Gallery
Gen6 Change automatic door locks function
I want to change my automatic door locks but I can't seem to get it right. I want the doors to lock when I put it in drive (the factory default) and unlock when I open the drivers door (not when I put it in park- again the default). I tried to follow the steps in the manual but it didn't work.
I turned the key to "ON" and within 10 seconds held the drivers die unlock button down for 5 seconds. I can't get it to lock and unlock the locks to "confirm" that it is set. What am I doing wrong.
2007 Camry SE V6
2001 Tundra V8
Agent WD-40 is offline   Reply With Quote
Old 07-26-2007, 07:54 PM   #2 (permalink)
View redman_eric's Photo Gallery
you need to put the car in neutral before you press the lock button
redman_eric is offline   Reply With Quote
Old 07-26-2007, 08:52 PM   #3 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
I turned the key to "ON" and within 10 seconds held the drivers side unlock button down for 5 seconds. I can't get it to lock and unlock the locks to "confirm" that it is set. What am I doing wrong.
Here you go.
scenario: turn off "doors lock when shifted out of park"
got in car
locked all doors
turned the ignition to on position (you will hear the chime noise 5 times)
within 1 second of hearing the chime... press LOCK for and let go before the chime noise go away after the 5th times to have doors not lock
scenario: turn on "doors lock with speed increase"
in car
locked all doors
with my e-brake on i moved the shifter to N
within 1 second of hearing the chime... press LOCK for and let go before the chime noise go away after the 5th times to have doors lock with speed increase
Old 07-27-2007, 04:57 PM   #4 (permalink)
I'll go give it another try. I am just about positive I had it in neutral though.
2007 Camry SE V6
2001 Tundra V8
Old 07-27-2007, 05:41 PM   #5 (permalink)
Here and there...
It took me a while to got it right then I realize that I had to let go the lock button (or unlock if you try to unlock) before the 5 chimes is over. Hope that help.
Old 07-28-2007, 04:15 PM   #6 (permalink)
Well I got it. I found out I had to disable the current function before I could enable a new function. I kept trying to ebable the function I wanted and it would cycle the locks to signify I did it correctly but it wouldn't keep the settings I wanted.
Once I disabled "doors unlock when putting the vehicle in park" (which was the factory default setting) was was able to enable the "doors unlock when you open the dirivers door".
2007 Camry SE V6
2001 Tundra V8
Old 07-28-2007, 07:00 PM   #7 (permalink)
View Goomph's Photo Gallery
I do not have the manual for my 2004 Camry ... Is it too much to ask if maybe someone can post all the stuff we can program regarding the locks ?
I am looking for a manual on eBay, but couldn't find one with that zippered black pouch yet ....
2004 Camry LE, Titanium Silver
4 Cylinders ! More than enough for my old bones
Goomph is offline   Reply With Quote
Old 07-29-2007, 12:48 AM   #8 (permalink)
View YotaSteve's Photo Gallery
Instead of starting a new thread, I'll try tagging on to this one..........
I know the dealer can change the locks to open all at once when using the key fob with only one puch, the factory default you have to push it twice quickly.
Any idea's?
07 Camry XLE - Love the factory JBL System!
YotaSteve is offline   Reply With Quote
How anyone can change the traffic lights green Misctick Off Topic 35 06-06-2006 10:45 AM
Gen 3.5 Oil Change camryelaine 3rd & 4th Generation (1992–1996 & 1997–2001) 4 05-19-2006 07:23 AM
15K miles trans fluid change? Joe B Archived Corolla threads 3 04-25-2006 05:35 PM
How to change timing of automatic door lock on `04 Toyota? highlander04 General Discussion 0 06-02-2005 12:32 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
