Wheels Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2007, 06:59 PM   #1 (permalink)
View amazin's Photo Gallery
Gen6 Wheels Question
Will these fit my camry? i have an SE. currently it has the 17 alloys. Thanks
http://cgi.ebay.com/ebaymotors/ws/eB...144080649&rd=1
07 Camry SE Black I4
Sunroof, Spoiler, 6 CD Bluetooth
amazin is offline   Reply With Quote
Old 07-28-2007, 07:50 PM   #2 (permalink)
Gameroom cash: $555540
View Camread's Photo Gallery
your 17s looks better than those
Camread is offline   Reply With Quote
Old 07-28-2007, 08:04 PM   #3 (permalink)
are you being sarcastic?
Old 07-28-2007, 08:32 PM   #4 (permalink)
it is what it is
akira751's Avatar
View akira751's Photo Gallery
Gen6
Whats the offset of the wheels???
07 Camry SE V6, Nav Mag Grey,18" Nex-0 gun metal, Trd Springs,K&N Typhoon Intake
http://www.cardomain.com/ride/2475669
akira751 is offline   Reply With Quote
Old 07-28-2007, 09:21 PM   #5 (permalink)
They are 19x9.5 Konig Unknown wheels and are 5-4.5 (5-114.3) bolt pattern.
Width: 9.5J
im not sure what these numbers mean besides that the 19 is the wheel diameter and the 9.5 is the wheel width.
Old 07-28-2007, 09:43 PM   #6 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
5x114.3 is the bolt pattern. There are 5 bolts in a 114.3mm circle
You need to know the offset to determine if those will fit.
2007 Camry 2.4L 5M
Old 07-29-2007, 11:13 AM   #7 (permalink)
ok i just found out that the offset are 25. can you please let me know what the offsets are?
Old 07-29-2007, 11:22 AM   #8 (permalink)
Support Authenticity!!!
moky-tron's Avatar
View moky-tron's Photo Gallery
they wont fit. they will be poking out of the fender well and might have a rubbing issue. depends on the tires you plan on using as well as if you plan on having a tire stretch.
The offset of a vehicle's wheel is the distance between the centerline of the wheel and the plane of the part of the wheel bolted to the hub. It can thus be both positive and negative, and is typically measured in millimeters. Offset has a significant effect on many elements of a vehicle's suspension, including suspension geometry, clearance between the tire and suspension elements, the scrub radius of the steering system, and visually, the width of the wheel faces relative to the car's bodywork.
Zero Offset - The hub mounting surface is even with the centerline of the wheel.
Positive Offset - The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative Offset - The hub mounting surface is toward the back or brake side of the wheels centerline.
moky-tron is offline   Reply With Quote
Old 07-29-2007, 11:26 AM   #9 (permalink)
no, bigger is not better in this case. those look cheap - hence $299 for a 19 new
Old 07-29-2007, 11:28 AM   #10 (permalink)
ok, thanks for the info. i already placed my bid on them lol, but i dont think ill win them for the price i bid. So what offset should i be looking for if i wanna get 19s. and from experience guys any difference in the comfort of the ride if you get 18 vs 19 vs 20?
Old 07-29-2007, 11:29 AM   #11 (permalink)
these retail for 299 each rim, is that still cheap, i checked a different site and the actual retail value is like 264 for that size. Konigs are good, or are they not?
Old 07-29-2007, 12:59 PM   #12 (permalink)
moky-tron's Avatar
max i would go for the camry would be 9" width with an offset of +35.
depends also if you will be lowering your car. id go for 19x9" +35 offset, and with a lowered suspension id go for 245/35/19, depending on the brand of the tires. falkens usually have a wider tread.
Old 07-29-2007, 05:39 PM   #13 (permalink)
View middleoroad's Photo Gallery
i like the rims on your car better too the ebay ones are a little too "busy" a simpler rim seems to look good on these camrys
middleoroad is offline   Reply With Quote
Old 07-29-2007, 05:57 PM   #14 (permalink)
been around the block
View SourDieseL's Photo Gallery
anyone got any wheel lock recommendations? or should i not even bother with something expensive? will anything do?
SourDieseL is offline   Reply With Quote
Old 07-29-2007, 06:00 PM   #15 (permalink)
it is what it is
akira751's Avatar
Gen6
I went with Mcgard premiums.
And you thought buying new wheels was fun... slvrAZtaco 2nd Generation (2005+) 12 03-23-2007 09:37 PM
Did Search , Question 06 trd wheels planohog 2nd Generation (2005+) 4 02-03-2007 02:50 PM
97 camry wheels question Live1521 3rd & 4th Generation (1992–1996 & 1997–2001) 3 06-25-2003 04:26 PM
A Question about Wheels jus1 Camry & Solara Lounge 18 06-24-2003 08:14 AM
matrix TRD wheels question SGG 1st Generation (2003-2008) 2 04-27-2003 06:48 PM
