My progress is just starting on one headlamp for now. I've taken off the lens cover and have already started measure for a bracket first.
But then it looks like I don't quite need to mod the headlamp assembly or the projector itself. I think I might be able to get it with just making a bracket for it to fit on, and try to see if it's level. If anyone else has experience with this, please chime in for suggestions.
Anyone think the stock halogen projectors could fit into the fogs? lol.
I'm working it with this friend of mine, I already have H11 wiring harness from ebay, but he said its not required at all. True?
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
The problem is that the shroud will not line up with the projector unless you modify the housing to scoot the projector closer to the inner part of the assembly.
__________________ Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals “My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
agreed
check it multiple times ..... mine ended up being 2-3 mm off centered
just enough to piss me off
make sure you read up on how to have them properly aimed so not to blind people
good luck and post pictures.
__________________ ~07 Magnetic Grey SE I4 ~
FX35's ~ 4300k Philips D2s ~ Matsushita Gen3
Blazers ~ Side Indicators ~ 6 Superflux Per
40% Silver Tint ~ 36 LEDS In My Trunk ..... http://www.putfile.com/n8dogg455/images Next Projects: IS300 Fogs ~ Superflux Tails / Turns / Reverse
I strongly suggest you use the wiring harness..what does the harness look like from ebay?
it bascially draws power from the battery directly instead of your stock wires ..so that the HIDs won't burn your stock wires..
Here are just some in progress pictures. I'm still trying to figure out the bracket, but this is with some shoestring and pieces of metal to test it and see how it aims first, so we'd know how far the projector has to be out.
Yeah it does look like I'll have to trim off part of the projector to have it fit fine, but I don't think I need to trim the housing itself.
What did you use to make sure there is no condensation? The rubber grommets wont fit the same.
Test fitment:
Dude, why do you have 1 TSX projector and 1 RX330 projector?
He doesnt, He is comparing the TSX projector with the stock Halogen Projector.
2005 Lexus ES330
i would suggest yo actually attach down the projector.
in the pics it looks like you are using a zip tie, and some sort of metal brace thing ....
they might serve purpose while you are working on them, but you don't want all your hard work go down the tubes on the first pothole you hit ....
keep up the hard work tho, it will be worth it
I'm guessing those were merely staging implements for the purpose of photography.
This is where you insert your signature
2005 Lexus ES330
Yeah I used shoe string and some braces temporarily to see how the projectors are aimed on the car. I'll definitely actually attach it to a bracket that I'll make.
I did power it on, and the light is so much better then my stock halogen projectors. I have an RX330 with HIDs as well, and it seems that these are quite a bit better with much more color.
I might considering either selling my stock halogen projectors or use them as fog lights, but then that'll be another retrofit...
That's a real nice color on those projectors. Is the washer mod just putting washers between the lens and the bowl?
