Speedometer Error - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2007, 08:37 PM   #1 (permalink)
View DBIGMAC1's Photo Gallery
Gen6 Speedometer Error
Driving home from vacation yesterday I noticed when passing the speed radar on the highway that it said I was doing 72 when the speedometer said i was doing 76. The same held true at the 2nd and 3rd ones I passed. My GPS unit matched the readings from the radar checkpoints. I'm trying to book an appointment with Toyota but was wondering if anyone else has had the same issue?
'07 Camry LE 2.4L Silver
'95 Camry LE 2.2L Gold
DBIGMAC1 is offline   Reply With Quote
Old 07-30-2007, 09:28 PM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Do you have the stock tires and wheels? I know aftermarket ones with a slightly different tire cause the speedomete not to register correctly.
geoff5093 is offline   Reply With Quote
Old 07-30-2007, 09:38 PM   #3 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
I've had the same issue with my last 5 Toyotas. It is a slight error they seem to build in on the high side and I don't think there is anything they can do about it. If you have any luck, get the specifics of the repair, please. I've never had any luck, and just figure it accordingly.
gdanaher is offline   Reply With Quote
Old 07-30-2007, 09:43 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
My speedometer reads about 3 mph high also with stock tires also.
Old 07-31-2007, 12:12 AM   #5 (permalink)
Yea, stock tires (steel rims & hub caps) <-- I need the 20hp I get from the hub caps.
Old 07-31-2007, 08:29 AM   #6 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
I have the opposite problems with my SE V6.
Mine reads lower than I'm actually going at highway speeds. That's my suspicion anyway.
I've ran side by side with my dad and while his car shows 120, I'm doing just 116.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 07-31-2007, 08:45 AM   #7 (permalink)
View marc780's Photo Gallery
The car manufacturers know there is going to be SOME speedometer error in almost every car, so they design them to read just a little high. Look at every professional test done b y the car magazines, where they use instruments to measure actual speed, indicated speed is always lower.
Some people check their speedo by driving along behind or in front with somebody else in another car at some agreed upon speed and just note the difference. If it reads two or three miles higher than actual speed i dont see much problem, at least not one worth throwing lots of money at. If it reads too low then its a warranty issue and they can probably fix it by reprogramming or something that wont take days to fix.
Old 07-31-2007, 08:52 AM   #8 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
You also need to account for errors in the radar based on your distance from it and it's own calibration. Usually the ones that are left on the side of the road for display are off by a few mph.
This is where you insert your signature
wireless is offline   Reply With Quote
Old 07-31-2007, 09:05 AM   #9 (permalink)
View Aceventura9586's Photo Gallery
I say you just leave it be. Having a speedometer thats not calibrated will get you out of a speeding ticket!
Aceventura9586 is offline   Reply With Quote
Old 07-31-2007, 09:28 AM   #10 (permalink)
wireless's Avatar
No it won't. Your own inability to maintain proper working equipment is no excuse for violating the law. Non-calibrated radar is another story.
Old 07-31-2007, 03:02 PM   #11 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
It can at times.
Not all states have that law.
Minnesota does, but a Judge will usually take a mechanical problem into account as long as it's repaired. I've beat several tickets that way (and helped family).
2006 Camry LE Special Edition
Old 07-31-2007, 03:18 PM   #12 (permalink)
wireless's Avatar
Originally Posted by TRD VVTi
It can at times.
They also elected The Body to run the state...not much for credibility j/k
Seriously though, since when is ignorance of the law or negligence of maintenance to legal regulations allowable exemption from following it? I guess I am too used to living in Virginia where traffic enforcement is taken über seriously.
Old 07-31-2007, 04:29 PM   #13 (permalink)
Yes it is taken alot more seriously in VA. Which is why I like driving in VA, cuz they get the other dumbasses off the road, but in MD, if your speedometer is not calibrated, you will get off from the ticket. The court takes into consideration the possibility of mechanical error from the factory, also that you had no way of knowing it was off, nor is it required for you to have it checked. There's loopholes foreverything, sometimes taht isn't good.
Old 07-31-2007, 04:45 PM   #14 (permalink)
View proteus220's Photo Gallery
I thought I was the only one with this "issue" as well. Passing one of those "your speed limit" radar trailers, everyday and mine reads 4-5 mph too high. I have a portable Garmin GPS unit which states the same....the speedometer is reading 4-5mph too high.
Occurred when new on stock tires and steel wheels, and problem still exists with new tires on the genuine Toyota 16inch alloy wheels.
Over the long run, doesn't this mean that you will have more miles than actually driven? Let's say I drive for 1 hour at 70mph constant according to the speedometer which is reading 4-5 mph too high. Doesn't that mean I've "actually" driven 65-66 miles during that hour, even though the odometer says 70 miles during that 1 hour?
proteus220 is offline   Reply With Quote
Old 08-02-2007, 12:57 PM   #15 (permalink)
Gameroom cash: $303755
How do you know your dad's car's speedometer is accurate? His can be off on the high side even more than your car.
Mike
speedometer not working namda1234 89-95 Toyota Pickup/Hilux 10 01-22-2008 03:40 PM
1989 22re Toyota Pickup Speedometer cluster problems Nebah617 89-95 Toyota Pickup/Hilux 2 03-28-2006 06:55 PM
Speedometer madness Arved 89-95 Toyota Pickup/Hilux 3 03-04-2006 07:48 AM
2006 Speedometer Error LandShark 5th & 6th Generation (2002-2006 & 2007-2011) 6 12-24-2005 07:44 PM
speedometer correction bfh4n Hardcore Tech and Competition 2 10-26-2003 12:39 AM
