is there an autodimming mirror glass that won't vibrate with my subwoofers? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2007, 11:45 AM   #1 (permalink)
View ToyotaLexus's Photo Gallery
Thanks!
ToyotaLexus is offline   Reply With Quote
Old 07-31-2007, 02:12 PM   #2 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
Probably not, without a custom job. Don't thump so f'in loud when you're driving
This is where you insert your signature
wireless is offline   Reply With Quote
Old 07-31-2007, 04:10 PM   #3 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
^+1
you'd need a solid mount to the windshield, with no adjustability. even then, i'd think it would vibrate. there's just no way around it... except turn your bass down!
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 07-31-2007, 04:16 PM   #4 (permalink)
secrecyguy's Avatar
View secrecyguy's Photo Gallery
I agree with both posters!
I bet you car is very loud!
2002 Toyota Camry LE
I got it used in May 07 at 32,000 miles
Currently has 65,000 miles.
secrecyguy is offline   Reply With Quote
Old 07-31-2007, 04:16 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1340697
Post some pics of that setup!!
Old 07-31-2007, 06:01 PM   #6 (permalink)
scamry's Avatar
Gameroom cash: $193525
View scamry's Photo Gallery
every type of mirror ever made will stop vibrating, once the volume is turned down a few notches.
not being a dick, but c'mon. (thats like asking if there is a lowering kit that wont make the car too low)
I miss the old days of TN.
scamry is offline   Reply With Quote
Old 07-31-2007, 08:20 PM   #7 (permalink)
View DigitalFool's Photo Gallery
Move you head side to side very fast - the mirror will stop vibrating...in theory.
DigitalFool is offline   Reply With Quote
Old 07-31-2007, 10:38 PM   #8 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
hm in our gen5 we dont have the auto dimmer and it vibrates like crazy. The auto dimmer in thej gen6 is alot stiffer than ours in the gen5 and it vibrtates likes a mofo. Juste get used to it i guess. or turn your bass down
CamrySExxx is offline   Reply With Quote
Old 08-01-2007, 07:33 AM   #9 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
It's the mount that vibrates. And you don't need a lot of bass to make it happen either.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 08-01-2007, 09:11 AM   #10 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Old 08-01-2007, 07:25 PM   #11 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
There are a couple of things you could try. The first is to add weight to the mirror so it doesn't resonate at the same frequency. First try taping weight to the back at see if it helps. If it does, take the mirror apart and put weight inside. The other thing you could do is to add a small peice of rubber tubing between the top of the mirror and the underside of the mirror mount. Try 3/16" vaccuum tube and trim it down so you can wedge it in. Also make sure that the mirror is mounted tight.
Rapid Roy is offline   Reply With Quote
6.5" subwoofers? mauibuilt59 Audio, Video, and Security - Tech 15 01-20-2006 04:48 PM
