Tail light not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2007, 06:47 PM   #1 (permalink)
View jaep0913's Photo Gallery
Gen5 Tail light not working
This seems to be a common problem on gen 5's. I always see gen 5's with either one or both of their tail lights not lighting when they brake.
Both of my tail lights wont light up when i press the brake. Thank god i have a spoiler...
I checked the fuse under my driving side, but the fuse isnt blown...
i tried to change the bulbs but that doesnt work either. I also checked the wiring but nothing is wrong... what can be the problem here ?
thanks guys
jaep0913 is offline   Reply With Quote
Old 07-31-2007, 09:31 PM   #2 (permalink)
bump !
Old 08-01-2007, 04:19 AM   #3 (permalink)
Camry 03 Sportivo
View poohbear's Photo Gallery
which fuse did you check for?
and there could be a connection problem with the bulb and the adapter..
and i assume this is happening on both sides?
Keep it stocky! http://www.cardomain.com/ride/2619744/
poohbear is offline   Reply With Quote
Old 08-01-2007, 06:32 AM   #4 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
seriously man, i'd say 99.999999999999999% it is your bulb or a corroded socket. If you say you put in a brand new bulb of the same type number and it still doesnt work, try cleaning your bulb socket with electrical parts cleaner/steel wool cloth or brush/SOS pad/wire brush/etc. then spray some white lithium grease or any kind of electrical contact grease and then try.
Try that first before you start ripping your car's wiring apart.
johnnyzee is offline   Reply With Quote
Old 08-01-2007, 07:14 AM   #5 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
might be silly but are u sure you got a dual filament(i think thats what its called) bulb? and i remember on my 93 when one tail light's bright lighting element(when you brake) went out, i had to replace both bulbs on each side for some reason for it to work..
MrSo0h0o is offline   Reply With Quote
Old 08-01-2007, 07:36 AM   #6 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Y'all keep saying tail light but I think you are talking about stop lights, and it might not be the same bulb. If the center light is working and the lower bulbs are not working, then you know the problem is not a switch or a fuse. They are all connected. Problem has to be the bulb or the socket it is plugged in to, so make sure you are looking at the right socket and then get about cleaning the contacts. If it isn't too badly corroded a pencil eraser will sometimes work to polish the surface. Other than that get a little drimmle tool to get down in there and polish the surface, and yes, check the new bulbs with a vom for continuity. The new bulb might be broken as well.
gdanaher is offline   Reply With Quote
Bent Rear Tailgate Tsb! seinfeldfour 2nd Generation (2005+) 465 10-19-2010 01:38 PM
My "Red light camera" essay Doctor J General Discussion 4 12-21-2006 07:19 PM
Guage light, tail light problem? Help? gezebo 3rd & 4th Generation (1992–1996 & 1997–2001) 5 09-01-2006 02:34 PM
stop light not working mister Joe Camry & Solara Lounge 8 05-31-2005 10:55 AM
Gen3 tail light idea CamryMax 3rd & 4th Generation (1992–1996 & 1997–2001) 11 04-22-2004 11:22 PM
