02 camry le 4cyl smoke at startup. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2007, 09:58 AM   #1 (permalink)
View joshuacball's Photo Gallery
Question 02 camry le 4cyl smoke at startup.
I have an 02 camry le 4cyl and it has 90k on it but smokes when I start it up after it sits a while. only after the car has been off for about 4 hours or longer mostly in the morning when I leave for work it pours out pretty good. Was wandering if anyone has seen this. The smoke is white. thanks.
joshuacball is offline   Reply With Quote
Old 08-05-2007, 10:11 AM   #2 (permalink)
silverxls's Avatar
View silverxls's Photo Gallery
hate to bear bad news. i've seen this in 2 circumstances. one is when the head gasket develops a leak, and coolant will seep in while sitting. if you have had to add any coolant this is probably your problem. the second is when oil return ports from the head have sludged up real bad. more oil will remain in the head and can then seep down the valve guides and will smoke worse on startup. remove the valve cover and you should be able to tell if it is sludged up or not, and a coat hanger can be used to put down the oil return ports to clear them a little, but this is not the best fix.
silverxls is offline   Reply With Quote
Old 08-05-2007, 10:12 AM   #3 (permalink)
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
That's a classic symptom of valve stem seal deterioration (or more seriously, damage or wear on the valve stems themselves). As time passes with the engine off, oil descends (leaks) through the stem-seal space and accumulates atop the valve, or in more extreme cases, dribbling over into the chamber itself. Once you start the car, the accumulated oil burns off generating the short-duration oil smoke. While the engine is operating, no oil can accumulate and therefore you see no smoke. Cycle repeats after the next long "off" period.
ekpolk is offline   Reply With Quote
Old 08-05-2007, 10:37 AM   #4 (permalink)
what is the intensity of this repair? Any "special" tools needed? Can I do this without pulling the head?
Old 08-05-2007, 10:37 AM   #5 (permalink)
ps thanks for the quick response
Old 08-05-2007, 11:05 AM   #6 (permalink)
View fat_bastard's Photo Gallery
The white smoke leads me to believe it's coolant getting in there somehow, prolly a head gasket. If it was the valve seals or oil getting in there the smoke would be blue. GL though...
fat_bastard is offline   Reply With Quote
Old 08-05-2007, 11:50 AM   #7 (permalink)
The Regenerator
ekpolk's Avatar
I'd agree with that. My thought is that the distinction between "white" and "blue" with this sort of smoke is pretty fine. For the OP, if it's really "cloud white" then it may well be coolant leaking into the combustion chamber(s). If it's got a bluish-greyish tint, maybe more likely oil. Either way, this is happening too early, which would suggest some form of neglect. Do you know the car's full maintenance history?
Old 08-05-2007, 01:06 PM   #8 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
ekpolk is taking the words right out of my mouth...
2006 Camry LE Special Edition
Old 08-05-2007, 03:20 PM   #9 (permalink)
not a head gasket oil and coolant are clean no milkshake so... back to the repair?
Old 08-05-2007, 04:10 PM   #10 (permalink)
Thats not necessarily true, just because there is no milkshake, that doesn't mean there's not a HG problem. It could be small enough to not make a noticable transfer, could be in such a place that they aren't mixing, just going into combustion chamber, or it could just not be in a place where you would see it. Only real way to check without ripping the head off is to do a compression check on each cylinder...
Old 08-05-2007, 04:12 PM   #11 (permalink)
could be intake gasket as well? correct?
Old 08-05-2007, 05:40 PM   #12 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
whatever it is, its unacceptable for a camry. 02, 90k miles, that's nothing. camrys should be more reliable than that.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 08-05-2007, 07:30 PM   #13 (permalink)
TRD VVTi's Avatar
Gen5
It's acceptable if the car hasn't been maintained properly...
Old 08-06-2007, 12:38 PM   #14 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Are you sure it is White smoke and not Slightly Blue Smoke.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 08-06-2007, 02:33 PM   #15 (permalink)
bike4miles's Avatar
View bike4miles's Photo Gallery
Does the smake smell nasty (burnt oil) or a little sweet and mild (coolant)?
My 2006 Camry:
http://www.cardomain.com/ride/2772438
My 1991 4runner:
http://www.cardomain.com/memberpage/510449
bike4miles is offline   Reply With Quote
Newbie 2007 Camry LE 4cyl Toronto JOL-07CamryLE Introduce Yourself Here 1 01-01-2007 01:02 PM
2000 camry le 4cyl engine swap question... DJboozeAlot 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-10-2006 07:07 PM
