2002 Camry SE 4cly strange noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2007, 11:19 AM   #1 (permalink)
View bostonbuzz's Photo Gallery
My 2002 SE with 46000 mi makes a strange noise when cold and I put it in reverse or drive and first hit the gas. It's fairly loud and sounds like a cross between a low octain knock/ping and a loose or broken exhaust heat shield. It lasts for a couple seconds. It's rather unnerving and an annoying sound coming from an otherwise fine automobile. When the engine is warmed up it goes away for the most part.
Any ideas? I had it by one of the repair shops that I do business with a month ago but they didn't really give it enough time to totally cool down to look/listen for the sound upon initial cold start up and drive.
Thanks for any help or suggestions...
bostonbuzz is offline   Reply With Quote
Old 08-06-2007, 11:50 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Where EXACTLY is it coming from?
2006 Camry LE Special Edition
Old 08-06-2007, 12:03 PM   #3 (permalink)
It sounds like it's coming more from the firewall forward rather than from the exhaust behind the cat pipe back. Hard to be 100% sure but if I'm standing outside the car and someone else is driving it sounds like it's more forward engine compartment as opposed to under center or rear ehxaust.
Old 08-06-2007, 05:20 PM   #4 (permalink)
TRD VVTi's Avatar
Buy a stethoscope for $10. Get someone else in your car to make the noise. You find out exactly where it's coming from. There isn't any way to help you over the computer.
Once you know what it is, I'm sure we can come up with the fix.
Old 08-06-2007, 10:37 PM   #5 (permalink)
View Aceventura9586's Photo Gallery
I don't know if this has anything to do with it but i'm having a problem as well. Sometimes on a cold start or rarely on a warm engine, i take the car out of park into reverse or drive, and there's this funky squeal, almost like the sound if a bad pulley or belt. That kinda noise. But yea, I have no clue what it could be.
Aceventura9586 is offline   Reply With Quote
Old 08-06-2007, 10:43 PM   #6 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
kind of like an engine pinging/knocking noise?
johnnyzee is offline   Reply With Quote
Old 08-06-2007, 11:33 PM   #7 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
i have a noise that occurs on a cold start also. and only on a cold start. It does it once, and then that's it. Sounded normal to me, i have the 1MZ though.
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 08-07-2007, 08:05 AM   #8 (permalink)
I'm going to try a better higher octane gas or a bottle of octane booster with my next fill up. See if that helps. I have gotten the rotten egg smell on occasion too.
Old 08-07-2007, 12:18 PM   #9 (permalink)
View aaron_c's Photo Gallery
My car sounds like it makes a pinging-type noise constantly, even with the cruise set on the highway. It sounds exactly like what my Dakota did when I gave it too much gas without downshifting. Also, mine did it yesterday with a heat advisory, so its not only when it's cold for me..
aaron_c is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
2002 Camry Factory JBL Navigation tkkidd Audio, Video, and Security - Tech 4 05-30-2010 06:41 PM
2002 Toyota Camry SE V6 egolub Vehicles 1 11-10-2006 06:46 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
2002 Camry SE test drive Tuesday.. Jzs147-RR 5th & 6th Generation (2002-2006 & 2007-2011) 6 08-06-2001 10:56 AM
