Security Wiring Questions for 07 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2007, 09:22 AM   #1 (permalink)
View boedyperrin's Photo Gallery
Gen6 Security Wiring Questions for 07 Camry
This place that I bought the after market keyless/remote start of course came with some awesome instructions......since I dont want to just start cutting wires and having a little "trial and error" session, does anyone know where the following are?
1. Tach Input Wire
2. (-) Neutral Safety Switch Input & (-) Remote Start Toggle Switch Input
3. (+) Positive Safety Shut Down for Brake
4. (-) Negative Safety Shut Down for Hood Pin Switch ( I assume this is just going to the Hood Pin)
5. (-) 200mA Channel 3 (Trunk) Output
6. (-) 200mA Programmable Output OR (-) Ground Output during Start (Crank)
7. (-) 200mA Domelight Supervision Output
8. (-) 200mA Programmable Output OR Dual Pulse Door Unlock Output (Factory Default) OR Factory Security Disarm Signal Output OR Start Status (Shock Sensor Bypass Conrol) Output
9. (-) 200mA Ignition 3 Control Output
It says that I can take #2 and Ground it when it is NOT USED for either of the connections listed.
There is also one more small thing on another harness. The Parking Light Relay Output and the Horn Output. Not sure where to find that.
Hopefully I can get this stupid thing in there because im about ready to burn it. They dont really have a place to find where this stuff is located on your car, they just tell you what it goes to. REALLY.....if I could leave all of this disconnected I would. Not sure if I can though.
boedyperrin is offline   Reply With Quote
Old 08-07-2007, 09:42 AM   #2 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
im pretty sure you can get them at the ecu which is behind my glove box. le 05.
look at the online manual for ID of each wire.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 08-07-2007, 10:12 AM   #3 (permalink)
Awesome! Thats great. So all of that stuff will be on the passenger side ECU? I think that I have found the drivers side ECU above the kick panel but I got a diagram from Toyota and their "wiring colors" were totally different from either online website. That was only for keyless installation though. Do you know where to find the wiring diagrams etc for the 07 Camry based on what you used? Thanks bud
Old 08-07-2007, 10:15 AM   #4 (permalink)
carlo$'s Avatar
everything you wanna know:
http://www.camrymanuals.com/index.ph...=110&topicid=0
master wiring: click on the third from the bottom link.
good luck.
2005 LE 4 cyl
Old 08-07-2007, 10:18 AM   #5 (permalink)
Wow. 507 pages! haha. Thats awesome. Thanks again!
90 Camry Security System Disable Mike C. Audio, Video, and Security - Tech 5 10-20-2008 11:45 AM
90 Camry Security System Mike C. 1st & 2nd Generation (1983–1986 & 1987-1991) 1 09-15-2005 02:25 AM
94 Camry - wiring harness? DailyDriveCamry Audio, Video, and Security - Tech 4 09-10-2005 09:14 PM
02 Camry Wiring Harness Problem amgine 5th & 6th Generation (2002-2006 & 2007-2011) 1 05-04-2004 04:54 AM
new member......camry questions 97sport Camry & Solara Lounge 2 06-08-2002 01:52 AM
