Academic fundamental question... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2007, 12:56 PM   #1 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
Gen5 Academic fundamental question...
for the 2005 camry doing mostly 85% highway miles driving pattern, which is the best struts to buy and install? Monroe sensa-trac, or KYB GR-2? Also, if i install the KYB GR-2 struts, which would be the best coil springs to use? OEM stock, or can i get a better spring, stronger, for a better high quality cadillac type ride.
Peter
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 08-09-2007, 01:14 PM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
i think both are pretty much equivalent to stock.. and since its hwy driving, it doesnt matter too much since u wont be hitting bumps often.. but i would go KYB
MrSo0h0o is offline   Reply With Quote
Old 08-11-2007, 12:41 PM   #3 (permalink)
self-proclaimed geenyus
jermyjerm's Avatar
View jermyjerm's Photo Gallery
Gen5
I bought a set of monroe sensa-trac far my 89 cutlass ciera one time.They suck.Floaty as hell.Only got tight when i would jump the car and land hard.KYB for sure.A set of SE springs would give you a less floaty ride but would feel less like the cadillac ride youre after.
jermyjerm is offline   Reply With Quote
Old 08-11-2007, 05:02 PM   #4 (permalink)
View sundarpn's Photo Gallery
Will SE springs fit the XLE? (2002 XLE in my case, was thinking if 2002 SE springs will fit? and also SE struts)
sundarpn is offline   Reply With Quote
Old 08-11-2007, 10:20 PM   #5 (permalink)
jermyjerm's Avatar
Gen5
I think so,and they fix the floaty ride.
Old 08-12-2007, 11:10 PM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Given the options you supplied I would go with KYB.
Personally, I wouldn't buy either one though.
I don't really understand what you are looking for in a spring. The information you provided seems to contradict itself.
2006 Camry LE Special Edition
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
Sub/Amp question Elizle Audio, Video, and Security - Tech 5 07-13-2006 10:42 AM
Hell Question MR2Jedi Off Topic 11 07-06-2006 10:20 PM
2007 Camry Question skippy126 5th & 6th Generation (2002-2006 & 2007-2011) 5 05-24-2006 07:47 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
