05 camry speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2007, 01:38 PM   #1 (permalink)
View bluecamry05's Photo Gallery
05 camry speakers
I was cleaning out my car today and i had the music up.. as i was cleaning the passenger side i realized the speaker for the front passenger had no sound.. i was wondering if anyone knew what brand the factory speakers are? and if i should get it replaced by the dealer or purchase aftermarket ones? if aftermarket which ones would you recommend.
thank you!!
bluecamry05 is offline   Reply With Quote
Old 08-09-2007, 01:47 PM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
do u have the JBL system? if so, then thats an obvious answer.. if not, then i believe they are fujitsu ten aka eclipse. u will have to get speaker adapters to fit aftermarket speakers in the existing baffles.
and in all seriousness, did u check if the fader was set to center?
MrSo0h0o is offline   Reply With Quote
Old 08-09-2007, 02:15 PM   #3 (permalink)
bike4miles's Avatar
View bike4miles's Photo Gallery
Usually a speaker doesn't just stop working if it goes bad, it will often distort or sound bad instead. Since there is no sound it sounds like a wire/electrical issue. I would sugest checking the peaker leads for power with a test light and go from there.
My 2006 Camry:
http://www.cardomain.com/ride/2772438
My 1991 4runner:
http://www.cardomain.com/memberpage/510449
bike4miles is offline   Reply With Quote
Old 08-10-2007, 02:59 AM   #4 (permalink)
yeh the fader was set center. I even tried setting the fader towards the passenger door and there was nothing. They are just stock speakers but yeah. I guess since there was no sound coming from that speaker, i thought that it blew and jumped to conclusion to buying a new one. But thank you guys for the tips, I will get it checked out and see what the problem is before anything. o and btw im new to the forums (: thanks for the help i appreciate it.
Old 08-10-2007, 09:44 AM   #5 (permalink)
2006 Camry Base
View whiteboy's Photo Gallery
if there's absolutely no sound then it's wiring 100% unless it's the stereo which I really doubt either fried wire somewhere or disconnected or cut, if it's fried unless you can see it doubt you'll be able to fix it might have to run new wiring for that speaker from under the dash, good luck finding it
whiteboy is offline   Reply With Quote
05 Camry steelies on a 98 Camry trd_4_life 3rd & 4th Generation (1992–1996 & 1997–2001) 7 04-25-2007 07:31 AM
Tips and Advice for installing rear speakers on Gen 2 (1990) Toyota Camry driving90 Audio, Video, and Security - Tech 15 02-23-2007 04:02 PM
Traded in my 05' Camry for an 07' Avalon CygnusX1 5th & 6th Generation (2002-2006 & 2007-2011) 1 01-08-2007 02:28 AM
new 05 camry owner bxcamry89 Introduce Yourself Here 0 08-10-2005 10:21 AM
How to remove front speakers on 88 camry? bobs Audio, Video, and Security - Tech 4 06-28-2005 10:01 PM
