Oil change GEN6 V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2007, 08:39 PM   #1 (permalink)
View 2ND_TOYO's Photo Gallery
Gen6 Oil change GEN6 V6
does anyone use a filter wrench to remove the filter housing?
I went to 2 parts stores and they didn't have one small enough to fit,
I asked the dealer (parts) and they told me to use channel locks, bad idea,
I also tried a strap wrench, not enough room, so I ended up wackin' it on the two tabs
until it broke loose....but that method sucked...anybody have the Toyota tool they talk
about on the filter instructions? or know where I could get an aftermarket one?
07 CAMRY SE V6- BLACK
2ND_TOYO is offline   Reply With Quote
Old 08-10-2007, 06:57 AM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
The official wrench is sold on line and I think I've seen it on Amazon. It is a 64 mm filter wrench. If you google, look for toyota filter wrench. There are 3 sizes in a kit that one manufacturer retails and you can buy just the one tht you need. Also, NAPA sells a 65 mm wrench that works just fine for less money, but it does a little slop because it is 1 mm larger.
gdanaher is offline   Reply With Quote
Old 08-10-2007, 09:44 AM   #3 (permalink)
View Mike Murrell's Photo Gallery
If I am not mistaken, the Gen 6 V6 Camry uses the 2GR-FE engine - same as Gen 6 Avalon. A type B cap works. This is also known as a 65mm/67mm 14 flute wrench.
The following may help.
http://members.cox.net/n0v8or/avalon_oil_change.pdf
Mike Murrell is offline   Reply With Quote
Old 08-13-2007, 11:45 AM   #4 (permalink)
Gen6 Filter tool
for the record I followed some links and here is the part:
http://www.asttool.com/detail_page.p...mber=TOY%20640
thanx.....
2007 Camry Oil Change FYI! Wizrd23 5th & 6th Generation (2002-2006 & 2007-2011) 139 11-05-2011 07:36 PM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 03:17 PM
2003 Camry LE V6 3.0 Oil Change SuperGT 5th & 6th Generation (2002-2006 & 2007-2011) 15 03-14-2006 08:07 AM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
