Lightweight Crank Pulleys - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2007, 06:36 PM   #1 (permalink)
self-proclaimed geenyus
jermyjerm's Avatar
View jermyjerm's Photo Gallery
Gen5 Lightweight Crank Pulleys
Surely you guys have an opinion on these.Just wondering what you guys thought.
jermyjerm is offline   Reply With Quote
Old 08-14-2007, 06:48 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
They will give you a slightly rougher idle.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is online now   Reply With Quote
Old 08-14-2007, 06:52 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
performance per dollar is low
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 08-14-2007, 06:59 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
They do not dampen harmonic vibrations. They are bad for the engine, particularly the crank and the valvetrain.
2006 Camry LE Special Edition
Old 08-14-2007, 07:19 PM   #5 (permalink)
jermyjerm's Avatar
Gen5
being an actual expert,what do you believe are the long term effects on the engine?
Old 08-14-2007, 07:27 PM   #6 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
A lightweight pulley would work great if you had the head redone, lighweight pistons, lightened flywheel, stage 3 clutch, custom fuel/engine management, larger injectors, header, high flow exhaust and a high flow intake system. Upgrading just that part is kind of like putting on one racing tire and expecting the car to handle better. You need to plan out your hop ups so all the parts work together.
Rapid Roy is offline   Reply With Quote
Old 08-14-2007, 07:29 PM   #7 (permalink)
TRD VVTi's Avatar
Gen5
It would work great at hurting that kind of setup even more. There's a reason for the huge market of better performing aftermarket dampers.
Old 08-14-2007, 07:30 PM   #8 (permalink)
2006 Camry Base
View whiteboy's Photo Gallery
this has been covered many times with a lot of flames as well pls search zpi pulley opinions or something there's a lot of info and fights there trd up there is right though to summarize
whiteboy is offline   Reply With Quote
Old 08-14-2007, 07:54 PM   #9 (permalink)
jermyjerm's Avatar
Gen5
ok so i searched and wow,should have done that in the first place.surprised some of you guys still speak to one another.also im curious if whitechocolate has had any problems with his such as oil consumption.
Old 08-14-2007, 08:02 PM   #10 (permalink)
The Connoisseur
CharmCityES's Avatar
im not sure of the long term effects (i know they do not damnpen harmonic vibtrations like a stock pulley does) or the performance gains, but i do know that ZPI manufactures a pulley for the scion tC that will fit the camry perfectly....
The "Executive Sedan"
Old 08-14-2007, 08:02 PM   #11 (permalink)
Rapid Roy's Avatar
The point I was trying to make is that those types of performance parts belong in a whole different engine setup. Its more for an all out race setup, not so much for street/everyday use. You are correct though. There are many better ways to boost performance and still have a daily driver.
Old 08-14-2007, 08:05 PM   #12 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Nope. Haven't had a single problem as a result of installing the pulley.
As far as "gains" go... there are dyno sheets from ZPI when they installed the pulley on a tC... from what I noticed, it just allows the RPMs to go up a little faster... but after a while of driving like this, you just get used to it and it doesn't feel any different haha.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 08-14-2007, 08:17 PM   #13 (permalink)
jermyjerm's Avatar
Gen5
so, if i just install the zpi pulley,get a lightened flywheel and some trd stickers, i should run0-60 in about 4.2?i could tape it.might have to change the framerate a bit.
Old 08-14-2007, 10:05 PM   #14 (permalink)
TRD VVTi's Avatar
Just get a penis pump. It would be cheaper in the long run.
Old 08-14-2007, 10:41 PM   #15 (permalink)
The Connoisseur
a swedish penis pump?
how did that get in there? thats not mine!
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 77 02-04-2011 07:08 PM
1jz lightweight crank pulley venom2727 Supra Forum 0 09-20-2006 02:28 AM
lightweight pulleys gasman Archived Corolla threads 1 07-18-2005 02:31 PM
who has lightened crank pulley's done? boroEF Hardcore Tech and Competition 33 07-14-2004 12:03 PM
Light-weight crank pulleys Punisher Archived Corolla threads 2 12-17-2003 02:23 PM
