Dome light and map light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2007, 11:14 AM   #1 (permalink)
View gen5camry's Photo Gallery
Gen5 Dome light and map light
Hello, not sure if this is a retarded question and i've searched the forum for answers but nothing specific came up.
How do you take off the dome light bulb and how do you open the stupid map light cover?
i've found a thread that taught to use a paper clip to pry it open and i've tried it but it's not strong enough at all.
please help.
gen5camry is offline   Reply With Quote
Old 08-19-2007, 12:07 PM   #2 (permalink)
2006 Camry Base
View whiteboy's Photo Gallery
i used a tiny flathead screwdriver you just pry it open the maplight you just stick it anywher ein the gap and push it out sorta the domelight there's a little cut to put it in and pry it open
whiteboy is offline   Reply With Quote
Old 08-19-2007, 01:37 PM   #3 (permalink)
thanks for the fast reply
how do you remove the dome light bulb? i tried to pull it off but its so tightly attached
Old 08-19-2007, 02:04 PM   #4 (permalink)
2006 Camry Base
pull on it, what i did was take the little screw driver put it in the loop of the bump and pull it out
Old 08-19-2007, 02:09 PM   #5 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
The dome light has two small holes big enough for a flathead screwdriver on one of its sides that you pry it out with.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 08-19-2007, 02:15 PM   #6 (permalink)
thanks guys for the quick responses
Interior light or Map light devind05 5th & 6th Generation (2002-2006 & 2007-2011) 14 07-16-2007 07:06 AM
Interior light or Map light devind05 5th & 6th Generation (2002-2006 & 2007-2011) 4 07-16-2007 12:03 AM
who was the guy that changed the Dome and Map light to LEDS? lotust 2nd Generation (2005+) 17 01-25-2007 09:21 AM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
