If I get Toyota remote-start for 07 Camry, will it be covered under extended warranty
I'm thinking about getting the Toyota remote start system for my '07 Camry.
Since it's going to be installed by the dealer, it will be covered by the original 3yr/36k
mile vehicle warranty.
However, if I get the 7yr/100k extended warranty from Toyota, will the
remote start system be covered as well?
TOWING BENEFIT:
If a covered component mechanically fails, as determinded by the Administrator, You are entitled to reimbursement for Your towing expenses to the nearest dealership or authorized repair facility, up to the limites specified in the Vehicle Service Agreement Informaion. Licensed professional towing agencies' or auto dealers' receipts will be required for reimbursement. Your deductible does not apply to this benefit. For reimbursement please refer to the "How to Submit Claims" section. This benefit will only apply upon authorization of a covered repair. SUBSTITUTE TRANSPORTATION BENEFIT:
If Your vehicle is inoperable and is undergoing a repair covered by this Agreement, then You are entitled to reimbursement for Your substitute transporation expenses up to the limit specified in the Vehicle Service Agreement Information. Licensed professional rental agencies' or auto dealers' receipts will be required for reimbursement. Your deductible does not apply to this benefit. For reimbursement please refer to the "How to Submit Claims" section. This benefit will only apply upon authoriztion of a covered repair. DISLOCATION BENEFIT: (IF INDICATED IN THE VEHICLE SERVICE AGREEMENT INFORMATION)
If you are over 150 miles from Your principal residence and Your vehicle is inoperable and requires overnight repairs covered by this Agreement, You are entitled to reimbursement for Your food and lodging expenses up to the limit specified in the Vehicle Service Agreement Information. Valid food and lodging receipts will be required for reimbursement. Your deductible does not apply to this benefit. This benefit will only apply upon authoriztion of a covered repair. COMPONENTS COVERED BY THIS AGREEMENT ALL MANUFACTURER-ORIGINAL EQUIPMENT PARTS INSTALLED BY THE MANUFACTURER OR YOUR SELLING DEALER ARE COVERED UNDER THIS AGREEMENT FOR MECHANICAL FAILURE, UNLESS OTHERWISE EXCLUDED. THE ITEMS LISTED BELOW ARE NOT COVERED.
Brake linings, pads, and shoes
Accessory drive belts
Spark plugs
Carpet
Chrome
Hoses
Rust and corrosion damage
Fluids
Seat covers
Dash cover and pad
Headliner
Filters
Clutch Friction disk and pressure plate
Interior and exterior trim and moldings, including but not limited to, cup holders, ash trays, covers, and vents
Windshield wiper blades (rubber component)
Door trim, handles, and fabric
Tires
Paint
Glass (including windshields)
Batteries
Bumpers
Shiny metals
Weather stripping
Nuts, bolts, clips, retainers, and fasteners
Hinges
Light bulbs
Vacuum hoses, lines & tubes
Heating hoses, lines & tubes
EXCLUSIONS AND RESTRICTIONS
This Agreement covers repairs to covered components, which have mechanically failed, as determined by the Administrator. This Agreement does not cover any breakdown, mechanical failure or expenses, which are due to, result from, or are caused by any of the following:
A condition that occured prior to the date You applied to purchase this Agreement ("Agreement Effective Date") or repairs to vehicles with damage caused by a previous improper repair.
Failure caused by modifications or parts not authorized or supplied by the vehicle manufacturer or Administrator.
Failure caused by a non-covered component.
Any component which has not failed, but which a repair facility recommends or requires to be repaired, replaced, or adjusted.
Abuse, or damage by collision, upset or falling objects, larceny or attempted larceny, theft or attempted theft, fire, explosion, or negligence.
Lack of normal maintenance (for example: adjustments, alignment, tune-up, oil and filter change, etc.) and any conditions caused by lack of or improper maintenance (for example: engine failure due to sludge or overheating).
Not maintaining proper levels of coolants, oils and/or lubricants or proper coolant/water ratio as specified by the manufacturer in Your Owner's Manual, Supplement, and/or Guide and any conditions caused by not maintaining proper levels of coolants, oils and/or lubricants (for example: engine failure due to lack of lubrication or overheating).
Contamination of fuels, fluids, coolants, oils or lubricants, including sludge, as well as rust, corrosion or other damage and any conditions caused by contamination of fuels, fluids, coolants, oils or lubricants.
Any alteration to Your vehicle or any component thereof that does not meet the manufacturer's specifications.
Any use of Your vehicle not recommended by the manufacturer in Your Owner's Manual, Supplement, and/or Guide.
Acts of God, war, riot, insurrection, natural disasters including, but not limited to: freezing, extreme heat, windstorms, rainstorms, nuclear contamination, lightning, dust storms, hailstorms, snowstorms, ice storms, earthquakes or floods.
Normal wear, including but not limited to, excessive oil consumption, loss of compression, or a gradual reduction in operating performance due to burned or leaking valves or worn piston rings.
Nor does coverage under this Agreement apply if Your vehicle:
Has been used for plowing snow, competitive driving, racing, or towing a trailer whose weight exceeds the manufacturer's recommendations for Your vehicle.
Has been used for hire to public, or to transport people for hire.
Has been used for municipal or professional emergency or police services.
This Agreement does not cover the cost of the normal maintenance recommended in Your Owner's Manual, Supplement, and/or Guide, or this Agreement.
If any material information provided to the Administrator cannot be verified as accurate or is found to be deceptive, no coverage will apply under this Agreement.
Coverage under this Agreement will not apply if You are not the owner/lessee of the covered vehicle AND the owner of this Agreement at the time repairs are performed.
Coverage under this Agreement will not apply to any repairs performed outside the United States of America or Canada
Coverage under this Agreement will not apply to any diagnostic charges made in connection with a covered repair.
You must obtain prior authorization from the Administrator before You have repairs made. If Your vehicle becomes inoperable outside of normal business hours and You cannot reach the Administrator, You may proceed with necessary repairs, but all other terms and conditions of the Agreement will apply. It is Your responsibility to contact the Administrator on the next business day, or assure that Your dealer or repair facility does so. Parts reimbursements will be calculated based on manufacturer's suggested retail price (MSRP). Labor reimbursements will be calculated based on standard industry practices, as determined by the Administrator.
YOUR RESPONSIBILITIES
In order for coverage to apply under this Agreement You must do all of the following:
In the event of a mechanical failure, You MUST TAKE IMMEDIATE ACTION to protect the vehicle from further damage.
You MUST have Your vehicle serviced as recommended by the manufacturer as provided in the Manufacturer's Owners Manual, Supplement, and/or Guide, including but not limited to:
Change engine oil and filter
Check and maintain all fluid levels
Service Automatic Transmission
Inspect front suspension and steering linkage
Inspect drive axle boots
KEEP ALL RECORDS OF MAINTENANCE FOR YOU VEHICLE. IF YOU PERFORM YOUR OWN MAINTENANCE, YOUR RECORDS MUST INDICATE WORK PERFORMED, DATE, PARTS REPLACED AND ODOMETER READING AT TIME OF SERVICE. RECEIPTS FOR PURCHASES OF PARTS AND FLUIDS OR SERVICE AND MAINTENANCE MUST BE RETAINED WITH THIS AGREEMENT FOR THE ENTIRE PERIOD OF THIS AGREEMENT. FAILURE TO PROVIDE RECORDS OF MAINTENANCE MAY RESULT IN THE DENIAL OF CLAIMS. THE ADMINISTRATOR'S RETENSION OF BROKEN PARTS, FOR INSPECTION OR OTHER USE, MAY BE REQUIRED FOR ANY REPAIR WORK.
So, this is stating that the remote start, if it did not come installed by the manufacturer, would have to be installed by the same dealer where the car was purchased in order to be covered under the extended warranty??
I was told by my Toyota dealer one year parts and labor on my Toyota installed remote start on both my Camry and RAV4.
Is the guy BS'ing me?
If and when the time comes,I'll find out.
Yes.
__________________ 2009 Audi TT 2.0T --- THE BEAST! 2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
I went to the dealer and asked a service advisor. He wasn't sure, so I had
him ask the service dept manager. The manager wasn't sure, so he called
Toyota.
According to Toyota's people in charge of warranty claim issues, the Toyota
extended warranty willcover the Toyota remote start system. They only
require that the system be installed by an authorized Toyota dealer and that
I keep the original receipt to show that it was installed at the dealer.
I asked the Toyota warranty people to mail me and the dealer service manager a letter stating what they told the service manager over the phone. This way I'll have a hard copy in case something goes wrong. The chances of something going wrong with the remote start system is remote.
