Engine Oils Put To The Test - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2007, 06:19 PM   #1 (permalink)
View cmathieu's Photo Gallery
Australia Engine Oils Put To The Test
Hi All,
The article below is a very good (and surprising) test on some of the popular engine oils and whether they stand up to the the manufacturer's claims:
http://www.carandimage.com/forums/showthread.php?t=4394
Rgds,
Charles
cmathieu is offline   Reply With Quote
Old 08-27-2007, 07:17 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Wow. Some of those results are very surprising.
I wonder how the formulations compare to those available in the USA though.
2007 Camry 2.4L 5M
Old 08-27-2007, 09:31 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Interesting.
It's so hard to get a good answer about oils.
I'm not a real big fan of the Timken bearing test but it's interesting regardless.
Cams, cranks, rods, bearings, etc. all have flat surfaces and not round surfaces that allow the oil to be squeazed off the sides like that test does. It's not really a real world environment.
2006 Camry LE Special Edition
Old 08-27-2007, 10:22 PM   #4 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Hmmm... the website isn't working for me.
geoff5093 is offline   Reply With Quote
Old 08-28-2007, 12:18 AM   #5 (permalink)
TRD VVTi's Avatar
I forgot to mention. The Timken Bearing Test can easily be defeated by simply adding a little bit of bleach to the mixture. We all know that bleach isn't a good thing to have in the engine, but it works great to cheat in this "test". Back in the old days, that's how alot of products made theirs look superior. That's a fact.
Old 08-28-2007, 12:39 AM   #6 (permalink)
06 Camry LE I4
View y_one2000's Photo Gallery
One big factor has been overlook in this test.
the temperature. It seems to me that this test is runing at room temp.
We know that oil inside the engine can reach from 80C to couple hundreds C.
And oil's viscosity changes based on the temperature.
Some engine oils are rated 0W-40, while others are 15W-40 in this test.
the 0W-40 is less viscous (thinner oil layer) than 15W-40 at low temperature.
To me this test is not comparing apple to apple. It does tell something I should look into, but not a reliable test result.
note: this test only compares wear resistance. but other considerations such as contamination absorption and oil break down should not be overlook.
06 Camry LE I4 auto, Ave 27 MPG.
TRD springs, sway bar, and strut brace.
y_one2000 is offline   Reply With Quote
Old 08-28-2007, 01:12 AM   #7 (permalink)
All valid points...there are definitely other factors that have not been taken into account for during this test...still I found it rather interesting
Old 08-28-2007, 01:53 AM   #8 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
Shucks, no Amsoil testing.
Epsilon is offline   Reply With Quote
Old 08-28-2007, 02:34 AM   #9 (permalink)
The Greatest
View CamNub's Photo Gallery
They say Mobil 1 is no longer a true synthetic.
If you want the best, you need this German Castrol stuff.
CamNub is offline   Reply With Quote
Old 08-28-2007, 01:56 PM   #10 (permalink)
View marc780's Photo Gallery
Im with the guy who posted this on that forum
Very interesting but I wonder how that test relates to an oils "real world" performance? A good oil has to do alot of things well under a wide range of conditions.
He's got a point, they only did a cursory test of one part of the oil's performance. I think a really accurate test would mean running a bunch of cars with these engines for 50,000 miles at least, and then tearing apart the engines and miking all the parts for wear. The test they did was too basic to really show anything about the oils...too many unanswered questions. How do these oils stand up to heat? How do the oils stand up at 3,000 miles? 5,000 miles? how effective is the additive package at preventing sludging, wear, foaming, etc.? None of these questions are answered by their quick tests.
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 07:30 PM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
Jasper remanufactured engine (5sfe) cupcakes 3rd & 4th Generation (1992–1996 & 1997–2001) 10 04-01-2005 04:09 PM
Diesel engine oils --> camry engine? KevinLi Camry & Solara Lounge 8 08-01-2004 10:27 AM
