checking oil on dipstick - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2007, 01:11 PM   #1 (permalink)
nj0ywatch1np0rn's Avatar
View nj0ywatch1np0rn's Photo Gallery
Gen6 checking oil on dipstick
I've been having trouble reading my oil level on my dipstick because of the way it is designed. There is a crink and therefore kinda smears above the highest dot. Does anyone else have this problem?
2007 Camry SE
nj0ywatch1np0rn is offline   Reply With Quote
Old 08-29-2007, 01:55 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Mine is straight. No problem.
gdanaher is offline   Reply With Quote
Old 08-29-2007, 02:48 PM   #3 (permalink)
View dayvers's Photo Gallery
not at all. my dipstick stands erect. wipe off the premature fluids then check again. if that does not work, you might have to surgically replace your dipstick with a new one since the one you have remains flaccid.
dayvers is offline   Reply With Quote
Old 08-29-2007, 03:03 PM   #4 (permalink)
sorry, i meant the sheath where the dipstick goes to is kinked not my actual dipstick haha. My dipstick is fine but when i pull it out, the kink on the sheath smears and i cant tell my lvl.
2007 Camry SE
Old 08-29-2007, 03:31 PM   #5 (permalink)
if that is the case my friend...
what you need to do is break the hole in nice and slow. the vaginal walls (for lack of a better term), will be inpenetratable at first. if its your first time you have to pull it out slow or secretions will make your test results null and void. ease into the hole as it is still young and tight. take your time and make sure not to rush this process.
let nature takes its course. once you have a steady rhythm going, you can slide the dipstick in back and forth with an aggressive manner. try different positions when you are trying to do the deed. you may stumble upon a position that suits you right in which you can get a positive test result.
Old 08-29-2007, 03:37 PM   #6 (permalink)
been around the block
View SourDieseL's Photo Gallery
took it way too far
SourDieseL is offline   Reply With Quote
Old 08-29-2007, 05:11 PM   #7 (permalink)
look at my name hahaha i know how that part works, i meant for checking my engine oil in my car
2007 Camry SE
Old 08-29-2007, 05:28 PM   #8 (permalink)
gotcha..
take it to the dealer
btw, i see you are from dallas. i still have debbie does dallas on betamax. i like the last scene in which mr. greenfield had intercourse with debbie. mr. greenfield was dressed up in his old football uniform and performed the deed with her. after the money shot, it flashed "touchdown" on the screen. that was a cute touch to a happy ending (pun intended)
DIY: Oil Change w/ pics 5.7L mhadden 2nd Generation (2007+) 14 02-05-2012 03:04 PM
2007 Camry Oil Change FYI! Wizrd23 5th & 6th Generation (2002-2006 & 2007-2011) 139 11-05-2011 07:36 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
