How To Remove Cabin AC Filter in Gen 5 Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2007, 03:34 AM   #1 (permalink)
View cmathieu's Photo Gallery
Australia How To Remove Cabin AC Filter in Gen 5 Camry?
Hi All,
Trying to work out how to remove the cabin AC filter in my Gen 5 Camry. I got as far as removing the glovebox but when I looked behind, I didn't see anything that I could easily remove to get to the filter. I am certain it must be full of crud right now.
Thanks all
cmathieu is offline   Reply With Quote
Old 08-30-2007, 06:07 AM   #2 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
did the searching for you as i was curious for myself:
http://www.toyotanation.com/forum/t197133.html
or a more detailed DIY:
http://www.cardomain.com/ride/2379797/13
johnnyzee is offline   Reply With Quote
Old 08-30-2007, 06:09 AM   #3 (permalink)
johnnyzee's Avatar
^ I just realized that only the little strut need be removed to access the filter (see 2nd link).
Old 08-30-2007, 06:31 AM   #4 (permalink)
Australia
Cool...thanks so much Johnny...that looks very easy indeed...I am gonna try it right now to see how filthy (or not) my filter is.
Will let you know how I go
Old 08-30-2007, 06:50 AM   #5 (permalink)
secrecyguy's Avatar
View secrecyguy's Photo Gallery
On my car, I didn't have to do it.
2002 Toyota Camry LE
I got it used in May 07 at 32,000 miles
Currently has 65,000 miles.
secrecyguy is offline   Reply With Quote
Old 09-14-2007, 06:34 AM   #6 (permalink)
Australia
Hi Johnny...tried to remove the ac filter in my Gen 5 but when I removed my glove compartment, everything looked completely different from the ones in the pic. I will get a digital camera and take some pics to show...so now I'm stuck I have no idea what to remove in order to get to the ac cabin filter.
Maybe the Aussie spec Camry is a little different??
Old 09-14-2007, 07:37 AM   #7 (permalink)
View Camry5genrocks's Photo Gallery
The cabin air filter is located behind the glove
box + the glove box must be removed.
• Open the glove box door.
• Remove the Phillips screw on the right side
of the outside of the glove box door.
• Slide out the connecting rod.
• Push in each side of the glove box to release
the tabs.
• Swing the glove box door downward.
• Slide out the cabin air filter housing.
• Remove the old filter and replace with a new
cabin air filter - make sure the filter in
properly seated in the housing.
• Slide the housing back into position.
• Reinstall the glove box.
Camry5genrocks is offline   Reply With Quote
Old 09-18-2007, 10:37 PM   #8 (permalink)
View bigdenis's Photo Gallery
Hi there cmathieu.
The Aussie Camries don't have the cabin filter, unfortunately. Sorry to disappoint you.
bigdenis is offline   Reply With Quote
Old 09-18-2007, 11:44 PM   #9 (permalink)
Fixing My Jet
Gameroom cash: $100550
View Meperezs's Photo Gallery
i just changed mine out a couple of weeks ago and it was NASTY completly black and blocked. I can feel/smell the diffrence.
If you can read this thank a teacher. If you can read this in English thank an Airman.
Meperezs is offline   Reply With Quote
Old 09-20-2007, 11:35 PM   #10 (permalink)
Australia
Originally Posted by bigdenis
Hi there cmathieu.
Thanks BigDenis
Not dissapointed at all...one less thing to worry about and it also proves that I wasn't going mad not seeing the filter behind the glove box..hehe...
That said, there is a very stale smell coming from the air vents when I use the airconditioning so I guess I might have some moisture build up in there...will have to get my Toyota dealer to check it out when the car is next serviced.
Cheers,
Charles
FS: Misc Gen 4 Camry parts (engine/interior/exterior) got_trd Car Parts for Sale 41 08-01-2007 03:10 PM
Cabin air filter Tundra05 1st Generation (2000–2006) 2 07-07-2007 06:08 AM
Cabin filter in 2002 Camry LE secrecyguy 5th & 6th Generation (2002-2006 & 2007-2011) 18 07-04-2007 05:39 PM
00 Avalon -need help Kbass888 2nd Generation (2000-2004) 10 08-13-2006 07:30 PM
GEn 4 camry solars glow guages ona gen 4 reg camry mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 15 05-18-2005 05:06 PM
