Cabin Filter Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2007, 03:33 PM   #1 (permalink)
View FiftysLost's Photo Gallery
I know the manual says to change the cabin filter at 15k if not sooner. Question is if you use the AC on recycle does that mean air is not going thru the cabin filter? If thats the case then the filter will last indefinitely.
FiftysLost is offline   Reply With Quote
Old 08-31-2007, 07:28 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It doesn't change the fact that debris gets through the cowl though.
It's really not that big of a deal or that big of any expense.
Just check it every 15,000 miles and replace it if needed. If it's hardly dirty, vacuum it off or bang the larger debris off of it and reinstall it.
I'm going to say this again, and some people get upset when I do. If the maintenance is such a big deal, and such a large expense to you it would be wise to get a cheaper car that you can afford the maintenance on. A Corolla or a Scion might be a wiser decision.
EDIT: It doesn't make sense to have a car that you can't afford the maintenance on. The car will deteriorate and you'll be upside down. Having a cheaper car that you can maintain will keep it's resale value up and allow for a step up in the future, when you have some equity.
2006 Camry LE Special Edition
Old 09-01-2007, 03:23 AM   #3 (permalink)
You get a kick out of being a wise guy? It's not about being able to afford the maintenance. For your information I paid cash for my 2007 SE. The reason I was able to do so is because I don't waste money. The first part of your response was all I was looking for, not a sermon. So just stick it with your can't afford BS.
Old 09-01-2007, 03:36 AM   #4 (permalink)
The Greatest
View CamNub's Photo Gallery
I haven't seen an 07, but it shouldn't be that hard to remove the filter to look at it.
And if you don't want to replace it, it's really not that big of a deal. A lot of cars don't even have air filters and those people are doing fine. If the air you're sucking in is getting really bad though change it.
CamNub is offline   Reply With Quote
Old 09-01-2007, 08:37 AM   #5 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
Suggestion
I've seen cabin filters with anywhere from 15-30k on them. It really is case by case depending on driving environments. I think 15k interval for an engine air filter is sufficient (for my vehicles) and 20k interval for the in cabin air filter is sufficent as well.
JMSinMD is offline   Reply With Quote
Old 09-03-2007, 11:33 AM   #6 (permalink)
07 Camry SE V6
wilfredcruz's Avatar
View wilfredcruz's Photo Gallery
I cjange mine at 15k it was pretty bad. next one will be every 10k
2007 Camry SE V6 /Leather/sunroof/JBL
Added: XM Sat Radio (Toyota), 18in Wheels (Rial), 3M Tints (35%), LED Interior lights. TRD Lowering Springs
Removed: Camry Se Badges
wilfredcruz is offline   Reply With Quote
Old 09-03-2007, 03:56 PM   #7 (permalink)
View woodman411's Photo Gallery
FiftysLost - I took out the cabin filter and placed my hand inside while the fan was running. As I switched from inside (recirculating) air to outside air, I felt air flow on my hand on both settings. However, on inside air, I noticed the air flow on my hand was not as strong as with outside air, but the air vents were pumping out more flow. This suggests that not all the air goes through the cabin filter. In other words:
Outside air:
- stronger cabin filter air flow
- weaker air vent air flow
- suggests most if not all the incoming air is going through the cabin filter
Inside air (recirculating)
- weaker cabin filter air flow
- stronger air vent air flow
- suggests only a portion of the air is going through the cabin filter
Therefore, the cabin air filter will not last indefinately, but will stay cleaner longer on recirculating air.
* WW
woodman411 is offline   Reply With Quote
Old 09-04-2007, 05:36 AM   #8 (permalink)
Outside air:
* WW
woodman411
That confirms my suspicion. I do all the maintenance that I can. I was thinking of the people that do not do any work on their car. The person who uses the recycle function all the time then takes it to the dealer for service at 15k and they replace a good filter and charge you, what, $30? Thanks for the information.
Old 09-04-2007, 03:02 PM   #9 (permalink)
I'm not a do-it-yourself kind of guy (even though I want to be :-) , but I can't think of a maintenance task that's any easier - 5 minutes tops, 1 philips screw driver, and $15 for the filter.
* WW
Old 09-04-2007, 06:03 PM   #10 (permalink)
The Connoisseur
CharmCityES's Avatar
i reccomend checking and replacing every 15k miles as reccomended....maintenence is cheap on a camry and if you find things like these to be too expensive, then buy a yaris
The "Executive Sedan"
Old 09-04-2007, 07:38 PM   #11 (permalink)
CorCamrySE, I think the original poster's point is that it might not be necessary depending on your air settings, but like you said, it's a good to check at regular intervals. My point is this particular maintenance task is easy money for the dealer... maybe a little bit too easy. For the value and time, it's something I recommend yourself doing, including the engine air filter, regardless if you have a $11,000 Yaris or $55,000 Landcruiser. Assuming the dealer charges $30 to change the air filter (let's say $15 for the filter), you are paying them $15 for labor. I can't imagine anyone paying the dealer $15 to check the air pressure in the tires, which is about the same time it takes to change the air filter and just as easy.
* WW
Old 09-04-2007, 09:08 PM   #12 (permalink)
The Connoisseur
* WW
haha i fully agree woodman....i was implying that the average camry owner can simply buy the parts and do thw ork themselves....id be more than haplpy to post a diy with photos for basic maintenence procedures such as this so people can do it themselves and save money on labor
the filter is a real simple change
Old 09-04-2007, 10:40 PM   #13 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
Change it after 90k like I did. xD
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 09-04-2007, 10:49 PM   #14 (permalink)
02
JMSinMD's Avatar
Wow
I think that's the worst I've ever seen. As I said before get it done at the same time you change your engine air filter. For that interval, be it 15k or 20k your engine and your a/c system are breathing the same air.
Old 09-04-2007, 11:17 PM   #15 (permalink)
The Connoisseur
i just change mine every 15k reguardless...i like to breathe clean air, and i like my camry to do the same
07 Yaris Cabin Air Filter so40 Yaris, Vitz and Echo Forum 19 02-02-2009 06:35 AM
Question on fuel filter replacing tonysun23 3rd & 4th Generation (1992–1996 & 1997–2001) 36 05-14-2008 12:02 PM
Quick Question - Napa Oil Filter Users hooch364 2nd Generation (2005+) 6 08-28-2007 03:36 PM
Longevity of Synthetic oils? Blackhawk3D 3rd & 4th Generation (1992–1996 & 1997–2001) 20 11-24-2006 11:59 PM
Cabin filter -disgusting ToyotaToday Camry & Solara Lounge 23 03-30-2006 05:35 PM
