Intake question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2007, 07:17 PM   #1 (permalink)
View bottlecaps's Photo Gallery
Intake question
Basically, ive removed that box in my I4 and replaced it with an intake ive built myself, Im using a Sceptre piece to connect my air sensor...
Problem is...engine doesnt stay on for more than 3 seconds before turning off
bottlecaps is offline   Reply With Quote
Old 09-02-2007, 07:20 PM   #2 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
Why not just buy an intake that's already out for your application?
Epsilon is offline   Reply With Quote
Old 09-02-2007, 07:43 PM   #3 (permalink)
I already have that in mind, I went to Pep Boys yesterday and they told me of a K&N factory that also retails parts in Torrance. This was basically just to increase a bit of knowledge
Old 09-02-2007, 07:59 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It seems that the factory intake worked much better, huh?
2006 Camry LE Special Edition
Old 09-02-2007, 10:07 PM   #5 (permalink)
The Connoisseur
CharmCityES's Avatar
you probably removed the maf (mass airflow sensor) from the oem intake....it has its own little bong into the intake tract.....my removing this, your engine will not run correctly as it throws off the computer
replace the stock intake or get an aftermarket unit with a maf bong and you should be set
The "Executive Sedan"
Old 09-03-2007, 12:38 AM   #6 (permalink)
Thanks for the input, TRD its actually working now and that flowmaster no longer sounds like a flowmaster, i'd have to do a drive by clip so you can see what i mean...sounds 10x's better...
CorCamrySE what I did was fit the sensor on the Sceptre part but turn the sensor so that that thing that looks like a resistor inside is in the direct flow of air...its working perfectly...Im thinking about a K&N or Weapon R for a permanent change
Intake System Question 01FIERA Archived Corolla threads 18 01-05-2006 09:50 AM
question about v6 intake NTL Camry & Solara Lounge 10 12-27-2005 02:49 PM
Question! .:Gen5 Air Intake System:. ModifierMR 5th & 6th Generation (2002-2006 & 2007-2011) 7 10-19-2005 03:01 PM
Air Intake Question skybandit MR2 Forum 3 06-22-2005 12:45 AM
Cold Air Intake Question MBKpitcha Introduce Yourself Here 3 02-08-2005 05:54 PM
