Coolant drain plugs on block? 2002 4 cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2007, 09:42 PM   #1 (permalink)
View makinson's Photo Gallery
Does the 2002 4 cylinder Camry engine have coolant drain plugs on the block?
If so, how many and how do I locate them?
Are there any special tricks to changing coolant (like bleeding)?
David
makinson is offline   Reply With Quote
Old 09-02-2007, 10:18 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
The drain is near the exhaust header.
2007 Camry 2.4L 5M
Old 09-02-2007, 10:21 PM   #3 (permalink)
The Connoisseur
CharmCityES's Avatar
its near the exhuast manifold....
www.camrymanuals.com
get the gen 5 manual and it should show you directions to anyting youre looking for in your camry
The "Executive Sedan"
Old 02-12-2008, 01:56 AM   #4 (permalink)
View clacker's Photo Gallery
Australia
Hey guys,
I've got the Gen5 manual and still can't see it. Is it below the thermostat housing near the compressor or is that too low?
Thanks
clacker is offline   Reply With Quote
Old 02-12-2008, 02:14 AM   #5 (permalink)
Australia
I should clarify I'm talking about the 2AZ-FE engine.
Old 02-12-2008, 02:16 AM   #6 (permalink)
It looks like a water tap with a 10mm, 12mm, or 14mm bolt on the end.
I think I stuck a 3/8" (~9.5mm) ID piece of clear hose on it to make draining less messy.
2007 Camry 2.4L 5M
Old 02-12-2008, 03:24 AM   #7 (permalink)
Thanks for the response. Using the diagram in the service manual, it appears to be on the left side of the exhaust somewhere around level with the thermo housing.
Am I looking in the right area? Can you only see it from under the car?
The manual only refers to the radiator drain plug in the draining procedure which I found odd.
Old 02-12-2008, 10:30 AM   #8 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It's right at the base of the block on the front of the engine. You really can't miss it.
2006 Camry LE Special Edition
Old 02-14-2008, 12:18 AM   #9 (permalink)
I've found the location from the manual but there is a coolant hose attached. Could the Australian version be different? Its the only coolant connection beneath the thermostat so I'm positive thats it.
Old 02-14-2008, 05:09 AM   #10 (permalink)
Australia
I've taken a picture if someone would be kind enough to verify. Thanks http://www.invitationave.com.au/file...y/IMG_5001.JPG
Old 02-14-2008, 07:10 AM   #11 (permalink)
TRD VVTi's Avatar
Yep, that's it.
Where does the hose go to?
Old 02-14-2008, 08:25 AM   #12 (permalink)
Yep, that's it.
Not sure, I'll check it out on Saturday and let you know. It drops down though so that drain is not at the lowest point which is a bugger. Thanks for that.
Old 02-14-2008, 08:34 AM   #13 (permalink)
TRD VVTi's Avatar
Mine has no hose at all. There is simply a threaded plug in the fitting that goes into the block.
Old 02-14-2008, 05:38 PM   #14 (permalink)
Interesting to see where it goes. I can verify its factory fitted as my mother in law has owned the car since new and nothing has been done to it.
Old 02-15-2008, 10:10 PM   #15 (permalink)
Australia
Ok, the hose ducks under the compressor and is attached to a metal pipe right above the oil filter. In fact I was wondering for a minute if it was an oil line as it looks like it would drain right into the filter. Its a September 2002 2AZ which I was told was one of the first so maybe that's why it's different or maybe something unique to Australian models? Be great if another aussie could confirm. Car is all done now. Thanks for your help!
Location of Coolant Drain on Engine Block ski46 9th Generation (2003-2008) 13 10-26-2011 07:40 PM
'96 GT Block Drain Plug GT '96 Celica Forum 1 07-13-2004 06:44 PM
coolant drain plug? CrawlingEye Camry & Solara Lounge 23 07-07-2004 09:11 AM
Engine block coolant drain? John Doyle Hardcore Tech and Competition 0 05-31-2004 10:34 AM
Engine coolant drain plug REDSOXTICKET Camry & Solara Lounge 2 05-23-2004 03:53 PM
