According to my mechanic, it take 3 to 4 days to fix the gasket problem, he need dismentle the engine block and change the gasket. It cost a bomb.
Hope the sealer do the trick..
what camnub said. I'd bite the bullet and fix it (myself) at the earliest opportunity. Where is the leak? You say the bottom, sorry but what does that mean? Oil pan? (not too hard and reasonably cheap to fix yourself if you know a little bit about wrenching). Rear main bearing seal? (The transmission has to come out.) Front main seal? (The timing belt components, covers, and crank pulley have to come off - but it beats pulling the trans any day.)
Like you say, the mechanic is gonna charge you a small fortune to fix this. If you know how and can do it, fix it yourself. Wash tne engine with simple green til it is clean as new - clean it twice if you have too - then pinpoint exactly where the leak is coming from. Then replace the gasket or seal.
