07-08 Camry HID Hi Beams - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2007, 10:33 AM   #1 (permalink)
View mnshooter's Photo Gallery
Gen6 07-08 Camry HID Hi Beams
When you do the HID upgrade for the H11 bulbs does that give you HID Hi Beams too or are you still stuck with the factory ones. Also has anyone put HID on their fog lights. I've done some searching but couldn't find anything about this.
mnshooter is offline   Reply With Quote
Old 09-03-2007, 11:23 AM   #2 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
No, in our Camrys the lo and hi beams are two seperate bulbs. The lo-beams are H11, while the high beams are 9005. Not many people need to replace high beams to HID bulbs, it is highly unnecessary, and even bad for the bulbs. You only use high beams to flicker them most of the time, and flickering HIDs are damaging to its lifespan.
You can just buy an H11 HID kit for your fogs, I have 2500K Nokya H11 halogen bulbs and they look fine, but an HID kit woul;d look great on the fogs.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 09-03-2007, 11:32 AM   #3 (permalink)
niko3257's Avatar
View niko3257's Photo Gallery
Gen6 high beams
i wouldn't do hids on high beams anyway cause they are also part of your drl system.
not sure how it will work but i don't think the outcome will be good
07 CAMRY CE
02 RC51/SP2
niko3257 is offline   Reply With Quote
Old 09-03-2007, 11:42 AM   #4 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $133432
View Yazovets's Photo Gallery
I'll tell you how it will work. See, DRLs are drawing low power, right?
So if you have a HID kit in there, you will see a flicker of the bulbs, but they will NOT ignite because there's insufficient power.
If you flash your lights for 1 second, then the HIDs will ignite because they will get that needed boost in power. Then they will remain on, but there will be terrible glare due to the reflector housing.
In other words, please don't do it.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 09-03-2007, 11:45 AM   #5 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
People put HIDs in their fogs all the time. As for HIDs in their hi-beams, not so many.
Epsilon is offline   Reply With Quote
Old 09-03-2007, 01:03 PM   #6 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Do NOT put HIDs in your fogs. It is dangerous because it WILL glare and blind other drivers, and does not look good. You will instantly become a cop magnet (and to be honest, if you do put them in your fogs, then thats a good thing, because they won't be there for long).
And Yazovets is right about the HID high beams. Its a terrible idea.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 09-03-2007, 01:41 PM   #7 (permalink)
Cathode Protector
View cosism's Photo Gallery
Yep, HID in highs or fogs, not a great idea. May I suggest Hoens or Nokyas. I just got a pair of hoen xenon match bulbs for my fogs to match the color of my 4300K lows, just an idea. Hoen also sells yellow fogs as well.
07' SE V6, TSX retro w/ color mod, Chrome 18" GS430 wheels, led bulb swaps, tinted windows, K&N drop-in, Sirius, door moldings(FTMFW!!!!). 2 Britax seats too!
cosism is offline   Reply With Quote
Old 09-03-2007, 01:54 PM   #8 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Is the only reason because of the DRL's? It seems like it would be a good idea since HID's are alot brighter, they would light up the road and surrounding areas quite well. If you don't use your DRL's, would it still not be a good idea?
geoff5093 is offline   Reply With Quote
Old 09-03-2007, 02:03 PM   #9 (permalink)
HID/Retrofit Expert
Actually, it wouldn't. Because of the reflector housing, you would have light in all sorts of places where you don't want it, and little light where you actually do want it.
EDIT: Its the exact same reason you wouldn't put HIDs in low beam halogen housings. Light spreads all over the place, except for where you really need it. You have to remember-- halogen housings are designed for only around 800-900 lumens of light or so. So the light doesn't bounce around so much inside the reflectors and doesn't glare. But you stick a 3000+ lumen HID bulb in there, and the light bounces all over the damn place.
Old 09-03-2007, 03:35 PM   #10 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
Gen5
exactly... and for the same reason, you wouldn't put HID's in the foglights... they aren't designed for HID's, the light would be scattered, probably inferior to halogen, and you'd have tons of glare, probably blinding people... if you wanna upgrade the foglights, just throw in some 2500K nokya halogens and call it a day...
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
Old 09-03-2007, 04:24 PM   #11 (permalink)
HID/Retrofit Expert
One other thing, you definitely didn't "search" hard enough, because I know that I have mentioned all this about HID fogs on several occasions on the forum.
Old 09-03-2007, 05:38 PM   #12 (permalink)
BANNED
View w203's Photo Gallery
The reflection of the high beam is more upwards than to the sides. The low beam projects nicely to the sides. You can switch the DRL off and save the bulb and ballasts if you want them in the high beam. But it wouldn't do much really since the eye can only see so much and the halogen highs do a good job with the lighting output.
Searching on a forum? Psh that is so last year.
w203 is offline   Reply With Quote
Old 09-03-2007, 10:24 PM   #13 (permalink)
geoff5093's Avatar
Thanks for answering my question, but on my way home Iw as also thinking it was a bad idea because you often flash your high beams on and off when traffic comes, so it would probably kill the HID's pretty soon.
Old 09-03-2007, 10:30 PM   #14 (permalink)
Wow, what's the deal with people attacking new posters with low post counts. I'm not going to spend countless hours searching and reading when I can post and get the answer much quicker. I have spent a few hours reading about HIDs and these are the questions I still had.
Anyways I didn't see any posts where someone actually installed fog lights on this model so I thought I'd ask. They said you could do it and that is it. Also nobody ever mentioned having XENON's for their high beams.
Thanks for all the help everyone.
Old 09-03-2007, 10:34 PM   #15 (permalink)
Gameroom cash: $255930
View LE05's Photo Gallery
just want to add that if you have reflector fogs, its a very bad idea to put HIDs in there. however, decent projector fogs with a clean cutoff are a good candidate for HIDs... some may debate that 3000k is a better color temp to use vs 4300k, but i believe its more personal preference.
pretty sure there's a couple threads on hid's in gen 6 fog lights... threads with some pics too. nobody mentions hid's in high beams because very few do it... its just a bad idea.
no one is attacking you... just some friendly advice! trust me... there have been far worse replies, what you've got now is nothing.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 09:42 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 11:55 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 10:50 PM
'07 Camry versus '07 Altima alsace 5th & 6th Generation (2002-2006 & 2007-2011) 115 02-07-2007 03:57 PM
'07 Camry versus '07 Altima alsace 5th & 6th Generation (2002-2006 & 2007-2011) 17 11-15-2006 09:30 PM
