Originally Posted by redfish
I check VG web site. They didn't shown a camry under toyota. So what fin did you get? Also how did you keep the wire from coming out of the groove between the window and body molding. And Will the fin work with XM sat. antenna that comes from the factory with the car? I noticed some wire under the fin? What is that for and how does it hook up to a magnet antenna?
That project turn out great!! And the color matches.
When I talked with the guys at VG they told me to use the Toyota Corolla when ordering but to specify that this was for a Camry in the special instructions field in PayPal. You would of course use the Camry colour code and name.
As for the antenna wire, I snuck behind the rubber gasket (or what ever it is) that's around the rear window. There's quite a bit of room there. I used two shirt collar insert...one to lift the gasket the other to push the wire in. This way I didn't scratch the paint or glass and they were thin enough to get the job done quickly.
I don't see why the fin would not work with XM...
The wire that you see inside the fin is used to connect to actual radio antennas that some cars like the Toyota Corolla and Mazda 3 have on the roof...for my application this wire and small circuit board were useless...
Look here...
Originally Posted by Punks_Not_Dead5
looks great! I know you said you'll take more pics later. I'd be intrested in seeing a side shot! But it looks great noless!
I'll take a few side shots this weekend...plus I have to post the Sirius radio install...
