I hear some reports of head gasket failure if overheating occurs. Is this a more common problem than the old 2.2L?
Any engine you can find is going to have issues if you overheat it badly enough. I blew up the engine on my 1985 Nissan 200sx by overheating from what i think must have been a stuck thermostat. I pulled the head and a piston was BROKEN and the cylinder ruined. The remains were no good even for a core! (That little mistake cost me over $1000 to fix.)
If anything Toyota builds a better 4 cylinder engine than almost anybody else. I know, i work for a fleet and we have cars and trucks from almost anybody you could name. The toyotas are better than any of the others by far.
I guess the answer to your question is maintain the cooling system and keep an eye on the gauge once in a while, just like you would on any other car. And just don't do what i did, if your gauge ever says your engine is too hot, STOP THE CAR NOW and dont restart it except for testing until you find what made it overheat! (in my case for example, if id just shut off the engine and waited a while to cool, and removed the thermostat and drove without it to get home - i probably could have saved myself all that money!)
