Reliability of 2.4L engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2007, 06:22 PM   #1 (permalink)
etc
View etc's Photo Gallery
How reliable is Gen 5 2.4L engine?
I hear some reports of head gasket failure if overheating occurs. Is this a more common problem than the old 2.2L?
I understand that 2.4L uses aluminum heads to decrease the weight but does it introduce realibility issues long-term?
How well does 2.4L work long term, has anyone put 100-200K miles on it without issues?
etc is offline   Reply With Quote
Old 09-03-2007, 06:25 PM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
I've got 86k with no issues. I know there are others with much more. The engine is reliable.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 09-03-2007, 08:10 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It's very reliable. That's why I purchased my Camry with the 2.4. Having an aluminum head on an aluminum block is actually better and more durable than having a cast iron head. The aluminum head doesn't create any problems at all.
Head gasket failure with overheating is common on nearly every engine. Overheating can ruin just about every part of the engine. Common sense usually will keep any damage from occuring.
2006 Camry LE Special Edition
Old 09-03-2007, 08:29 PM   #4 (permalink)
View Mike Murrell's Photo Gallery
TRD is correct - aluminum on iron is awful. Ask anyone with the old Datsun Z or older Mercedes cars with 4/6 cyl motors made in the 80s/early 90s.
Overheating will deep-6 any motor.
I have a 2.4 in an '04 Tacoma baseline. Good motor.
Mike Murrell is offline   Reply With Quote
Old 09-03-2007, 11:23 PM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $318410
View gdanaher's Photo Gallery
They do have steel sleeves though, right? Would hate to think of what might happen with hard anodize.
gdanaher is offline   Reply With Quote
Old 09-04-2007, 12:19 AM   #6 (permalink)
The Connoisseur
CharmCityES's Avatar
very reliable....we had a trade in 02 camry LE 4cyl with 210k miles and it still ran as smoothly and quietly as my 03 SE 4cyl with just shy of 50K
you treat it well and it will treat you well.
the aluminum block/aluminum head 2az 2.4 is a tough engine
The "Executive Sedan"
Old 09-04-2007, 01:49 AM   #7 (permalink)
71Corolla's Avatar
Gameroom cash: $485050
View 71Corolla's Photo Gallery
Maybe on some cars, but Toyota used the iron block/aluminum head configuration in 10s of millions of engines, going way back to the early 70's with bulletproof reliability.
You have to go back a long way and look fairly hard to find a series of engines from Toyota that were not reliable.
71Corolla is offline   Reply With Quote
Old 09-04-2007, 03:42 AM   #8 (permalink)
View EnderSavesTheDa's Photo Gallery
2az ftw
EnderSavesTheDa is offline   Reply With Quote
Old 09-04-2007, 08:42 AM   #9 (permalink)
TRD VVTi's Avatar
Gen5
Yep.
Old 09-04-2007, 09:04 AM   #10 (permalink)
You don't have to go far at all. Mid-90s - V-6 motors blowing head gaskets right and left. In this same period there was also an engine oil-sludging problem. Millions of engines affected.
In the old days, Toyota was great.
Today there are 3 American cars that have a higher J. D. Powers rating than Toyota(#6) and Honda(#5).
Once known as the Rising Sun....getting to be the Sinking Sun.
Old 09-04-2007, 09:11 AM   #11 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
I have 150K miles on my 04 2.4 everything is still orginal. I need to do the spark plugs soon. The only time it has missed a beat is when the battery die and I needed a jump.
drunken_panda is offline   Reply With Quote
Old 09-04-2007, 01:20 PM   #12 (permalink)
etc
Reason for my inquiry is scary threads like this. It appears there is mounting evidence 2.4L can develop head gasket problems. Not sure if overheating is involved or if it happens arbitrarily.
02 camry le 4cyl smoke at startup.
Old 09-04-2007, 01:25 PM   #13 (permalink)
TRD VVTi's Avatar
Gen5
Don't be scared. The majority of the time that an engine has problems like that prematurely are because it wasn't properly maintained.
If you take care of your car and do the proper maintenance at the proper intervals with the proper products, you should be just fine.
Old 09-04-2007, 01:26 PM   #14 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
2.4 is the best, descent power and good gas savings.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 09-04-2007, 01:34 PM   #15 (permalink)
etc
I just got a 2002 2.4L 5 speed.
I am fairly paranoid about maintaince and use Mobil 1 every 3-4K miles, and watch my temp. gauge as well as flush the coolant often enough.
There is very little you can do to maintain the engine otherwise. Oil + coolant flush. Am I missing anything? I was under the impression they were experiencing issues even while doing these things.
One trick when buying a used car is hitting the gas while parked in neutral and having someone watch the exhaust... you shouldn't see any white smoke come out of it. If it does, it needs major engine work (like in cases above)
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 12:48 PM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 02:04 PM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 01:54 AM
Can I use Synthetic motor Oil at 5k miles? Meteor_Proof 2nd Generation (2005+) 39 04-07-2006 02:00 PM
Engine number four, HELP heroteh Hardcore Tech and Competition 2 05-07-2005 06:07 PM
