07 Camry Intake (help) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2007, 06:24 PM   #1 (permalink)
View TMr Net Shark's Photo Gallery
Ok, I have a nice little problem here. I have a 2007 Camry with the same 2.4 liter engine as the Scion tC. Now I'm trying to get intake done on the car. I want to redo everyone from the throttle body up. Slight problems will include that Scion tC CAI will not work due to the fact that an electrical component is in the way of the tubing.... picture shown:
See that off to the side of the air box? It blocks it completely for any CAI. So now my option go down to short ram intake for the Scion tC but I still havn't seen any type of short ram. So if you do know of any, please post a link to one.
Now if that won't work, I figure that I have just remove the airbox and get a cone filter. Yet another problem... the MAF sensor is right on the air box. Easy fix, but I need help finding it. Is there any place where I can buy a universal mount for the MAF sensor so that I can mount it between the tube that goes to the throttle body.. and the cone filter?
And now for exhaust. I havn't looked at my exhaust system, but is it possible to do a axle back exhaust system for the car? Or whould I have to go along the route of cutting off the old muffler and welding on the new one?
Thanks for your answers!
TMr Net Shark is offline   Reply With Quote
Old 09-05-2007, 06:52 PM   #2 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
There's already various intakes out for the '07 Camry I4. For example, Spectre, Fujita, etc.
There's no bolt on exhaust system that I know of for the I4 yet, just the V6.
Epsilon is offline   Reply With Quote
Old 09-05-2007, 07:04 PM   #3 (permalink)
Right... so now the question is.. which muffler out there looks similar to the stock muffler?
Old 09-05-2007, 07:57 PM   #4 (permalink)
View bottlecaps's Photo Gallery
Make sure everything's in tight when your done. I was driving to class this morning to find my car stop repeatedly on a busy street. I thought it was a need to change oil because I havent yet, and when I got to a shop (missed class ) I found my intake had fell off...on top of that the guys who changed my oil claimed I now had to pay them $40 just for removing it and screwing the factory intake back in...all in all a $21.95 oil change became $65
bottlecaps is offline   Reply With Quote
Old 09-05-2007, 08:00 PM   #5 (permalink)
Epsilon's Avatar
The stock one.
Old 09-05-2007, 11:18 PM   #6 (permalink)
View vwkaferman's Photo Gallery
Let me get this straight. Your car was stopping intermittently on a busy street, and you thought that maybe the problem was that oil needed to be changed?
Then, you go on to say that your intake fell off, BUT you paid $40 to have it removed only to be replaced by the stock box, right?
Can I be your mechanic? I only charge $1000 an hour per visit, and I will guarantee your car for LIFE. Nominal visits apply.
Wow.
James
'74 Beetle 0-60 probably
'97 Cherokee 0-60degrees, sometimes
'07 Camry V6 SE - Chicks car
vwkaferman is offline   Reply With Quote
Old 09-05-2007, 11:36 PM   #7 (permalink)
Lol, I havent had the oil changed....since 6kmiles im at 16k now, kept putting it on the agenda and forgetting, so when that happened I first thought the thing was really f'd up due to that negligence...
Turned out the intake fell out, guy messed around, hooked it back up, leak near the sensor, all kinds of crap so I finally brought the factory one out of the trunk to put on and he said he'd do it...
Lol i really dont mind anymore...saved me from getting dirty before classes
Old 09-05-2007, 11:38 PM   #8 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
If you're on a budget, some guy on these boards actually cut off the end of the pipe from the beginning of the airbox and put a cone on the end of the cut off part. Extremo ghetto custom, but it'll give you the same effect (and no, I didn't do this to mine trdvvti and whitechocolate but i will commend a ghetto concept that works)
johnnyzee is offline   Reply With Quote
Old 09-05-2007, 11:39 PM   #9 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Keep it simple.
Install a TRD drop in air filter.
When TRD makes a muffler, install it.
It just makes life so much easier and the gains are the same (practically nothing).
2006 Camry LE Special Edition
Old 09-06-2007, 02:37 PM   #10 (permalink)
Originally Posted by TRD VVTi
Keep it simple.
I don't want gains (even though they are like 2-5 hp for both intake and exhaust).. I just want noise..
Old 09-06-2007, 02:54 PM   #11 (permalink)
Epsilon's Avatar
Turbonator and E-Ram is right up your alley then. You can always unbolt your exhaust.
Old 09-06-2007, 03:47 PM   #12 (permalink)
been around the block
View SourDieseL's Photo Gallery
CLASSIC!
SourDieseL is offline   Reply With Quote
My experience w/ a 07 Camry SE I4 auto Linck 5th & 6th Generation (2002-2006 & 2007-2011) 49 08-14-2007 08:05 PM
'07 Camry versus '07 Altima alsace 5th & 6th Generation (2002-2006 & 2007-2011) 115 02-07-2007 02:57 PM
'07 Camry versus '07 Altima alsace 5th & 6th Generation (2002-2006 & 2007-2011) 17 11-15-2006 08:30 PM
Newbie w/ 07 Camry ?? SevereCamry 5th & 6th Generation (2002-2006 & 2007-2011) 31 06-24-2006 09:36 PM
'07 Camry........or '02 ES300??? redgtxdi 5th & 6th Generation (2002-2006 & 2007-2011) 9 12-18-2005 03:11 PM
