I have an 07 manual and I'm not sure what that issue is. The car seems fine to me. The only thing that annoys me is that the RPMs go up when I press the clutch despite being off the gas.
I test drove that 02 with 80K miles on it. I immediatelly stalled it, apparently it needs more throttle to get moving than my Gen-IV 5 speed manual. I did adjust to it after stalling it about twice.
...The only thing that annoys me is that the RPMs go up when I press the clutch despite being off the gas.
Ditto that (for my 07 CE I4 M/T). The tach raises about 300 RPM's. I noticed that it happens on a friends 2004 Camry M/T. I'll have to ask my friend with a M/T Focus. I'm not worrying about it, maybe I'll ask when I bring it for the first oil change.
The only issue I do have with the trans, when it's cold, it's a bit jerky around the 2000/2500 mark. Seems to go away after a few minutes.
This happens because the car is anticipating you shifting to the next gear and raises the RPM's to help keep them up to lessen the accelleration time.
__________________ Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals “My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
Actually, this happens to match the gearbox gear speeds closer when downshifting. It's a factory way of getting the different gears closer to the same speed. Road Racers do it manually when they don't use the clutch so that it goes into gear smoothly and doesn't shock the drivetrain.
We have reached a point of no return in using computer technology in uncountable number of devices in everyday life. I believe the auto industry will continue to increase the use of computers in various functions of vehicles. For example,we have the ABS which uses computer control to help drivers avoid skidding.
A computer rolls down the windows now, adjusts vent/heat controls, runs engine, senses tire pressure, senses suspension.....
2005 Lexus ES330
Yer, the HVAC system, manual control, is electronically controlled now. The air flow control or temp control used to have a cable attached to the back of it, but now it's electronic.
I actually preferred the controls in my Gen 4 to the controls in Gen 5 and 6. Reason is that on Gen 5 & 6, the knobs you grab and turn the outside so without looking at the knob, you can't tell where it's pointed. On Gen 4, however, you grab the knob on the inside on a bar and you could feel where it was pointed without looking at it. The knobs on the Gen 5 & 6 do have tactile feedback for each increment, but without turning the knob all the way high or low, you can't really tell where it's pointed without looking.
2007 Camry 2.4L 5M
