Slight Pop noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2007, 10:23 PM   #1 (permalink)
View bottlecaps's Photo Gallery
Slight Pop noise
Does anyone know what that little pop/bust noise I hear after accelerating for a while? Sounds like its coming from the FLowmaster...
Another thing, I went to the Sheridan Toyota dealer over hear and inquired about the fixes for the slow acceleration...the guy said It wasnt being done for 4 cyl's...is this true? Or could this be....4 CYL discrimination??
bottlecaps is offline   Reply With Quote
Old 09-06-2007, 11:20 PM   #2 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
ok, i'll jab at this one first...
the pop you're referring to is probably just "backfire".
as for slow acceleration...you bought the 4 cyl, hopefully even test drove it, what did you expect?
johnnyzee is offline   Reply With Quote
Old 09-07-2007, 02:23 AM   #3 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
Do a search or just scroll down. Download the TSB, and read it. Then tell the service rep the same symptoms in the same wording on the TSB. Then they will do it for you.
Rapid Roy is offline   Reply With Quote
Slight clicking noise from rear end?? LeDevil Pre-88 Toyota Pickup/Hilux 4 11-15-2006 07:36 PM
ABS pump type sounding noise at low speeds. VDoubleUVR6 RAV4 Forum 2 10-29-2006 06:47 AM
Problem with noise at 2100 rpm Cyberdave Camry & Solara Lounge 2 06-29-2005 11:10 AM
2004 Camry 4cyl A/T Booming Noise in Rear LPB 5th & 6th Generation (2002-2006 & 2007-2011) 2 04-22-2004 05:18 PM
front end groan squeal noise jcarol Archived Corolla threads 1 07-07-2003 08:04 AM
