07 XLE V6 - thump noise when cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2007, 09:09 PM   #1 (permalink)
sleekaman's Avatar
View sleekaman's Photo Gallery
Canada 07 XLE V6 - thump noise when cold
Not sure if this has been discussed, when I take my car out of the garage every morning since I got it, when I reach 10-13km (I noticed the speed today), I hear a thump or a flapping noise coming from the engine compartment (only once), has anyone experienced this before. I'm suspecting its a speed sensitive activation to lock the doors. My default setting in the service manual is set to AUTO lock when I put the car in Drive. And thought if it was changed, that flapping noise would activate the locking of the doors ? Or even the seatbelt buzzer.
This info can be found in the 'Body Electrical - Multplex Communication BE-13 , Customized Body Electronics System' section of the service guide. Any truth or am I dreaming ?
I'm planning to get these changed when I go for my 1st oil change:
- Disable that damn seatbelt buzzer
- Disable that AUTO A/C compressor on, so I can manually turn it on.
- Disable auto door lock when Drive is selected.
Harvey.
07 Camry V6 XLE (Family Cruiser)
03 Corolla LE (Daily Run-About)
85 Celica GT-S (Summer Fun Car)
http://sleekaman.webs.com/
sleekaman is offline   Reply With Quote
Old 09-07-2007, 10:07 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It's probably the ABS.
It's normal.
Do a search.
2006 Camry LE Special Edition
Old 09-08-2007, 10:35 AM   #3 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
I have your problem.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 09-10-2007, 01:06 PM   #4 (permalink)
View CanadianDad's Photo Gallery
Yep, ABS reset/check. Normal.
2012 Highlander Limited, Pearl White
2005 Matrix XR, White
CanadianDad is offline   Reply With Quote
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Oops!! I accidentally test-drove an '07 LE & V6 XLE!!!!!!!!! Uh oh! (c= redgtxdi 5th & 6th Generation (2002-2006 & 2007-2011) 16 05-18-2007 12:22 PM
Oil Leak 07 XLE V6 macaide 5th & 6th Generation (2002-2006 & 2007-2011) 7 02-17-2007 04:06 PM
07 Camry XLE V6 - Costco, Carsdirect??? writewun 5th & 6th Generation (2002-2006 & 2007-2011) 14 12-02-2006 10:07 AM
07 XLE V6 Audio ASL level jjthenovice 5th & 6th Generation (2002-2006 & 2007-2011) 11 04-28-2006 07:26 PM
