2006 Se V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2007, 05:43 PM   #1 (permalink)
View Jeremy_B's Photo Gallery
2006 Se V6
Question, I'm new to messing around with a camry, I used to have an s10 so parts weren't a problem to find. I am looking for a rear sway bar for my SE, but I can't find one. Am I out of luck? I called up TRD and they said the one posted does not fit a 2006. Does anyone have any suggests on mod's I should do and feed back on a rear sway bar?
Jeremy_B is offline   Reply With Quote
Old 09-10-2007, 08:16 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I asked the same question some time ago about my '06 and was never able to get a "for sure" type answer.
I suspect the the '04 TRD RSB will work. Someday I will order it and see for sure.
2006 Camry LE Special Edition
Old 09-11-2007, 04:53 PM   #3 (permalink)
Yeah it seems like we are kind of screwed owning 06's. The guy on the phone from TRD said the bolt patterns are different. Do you suggest any other mod's to an 06 SE V6?
Old 09-11-2007, 07:02 PM   #4 (permalink)
TRD VVTi's Avatar
Gen5
Actually, you could install an LE front sway bar. It's smaller in diameter and will make the car less tight.
The TRD strut tower brace works very well, as do the TRD springs.
Upgrading wheels and tires will help greatly also.
If I find that the TRD RSB will not fit, I will install an SE rear bar.
Besides the RSB, I've done everything that I want to do (for now anyways). You can click on the link in my sig and see everything that I've done.
The part number for Gen 5's is supposed to be PTR02-06041-01 and the Gen 5.5 is supposed to be PT901-48800-01. I haven't verified the part numbers yet.
http://www.toyotapartsstore.com/prod...d5b5e1378bcc57
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Purchase advice: 2004 Camry SE V6 or 2005 SE I4 Sedan Man 5th & 6th Generation (2002-2006 & 2007-2011) 30 08-23-2007 06:53 AM
2006 Camry SE V6 wheels rims and tires for sale ikl2 Car Parts for Sale 2 07-13-2007 03:03 PM
NEED 2006 Solara SE Sport Coupe V6 OEM Front Tire oxsekkie Solara 1 04-28-2006 02:18 PM
