2002 XLE - Steering auto return. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2007, 06:44 PM   #1 (permalink)
View sundarpn's Photo Gallery
When I make a tight turn (i.e. wheels turned all the way to one side), when I get straigth ahead, I expect that the wheel will spin back to center position almost completely automatically....
But I notice that this tendency to auto center is less and I have to help the steering to spring back & come to the center.
What is this problem called, the right term to use so that I can tell any aligment shop to look into...
sundarpn is offline   Reply With Quote
Old 09-14-2007, 08:26 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It's called self center.
You may have worn strut mounts/bearing plates (or other binding in the steering or suspension).
Caster is the specification that's responsible for self center.
Your expectation may be too high. It's not required to self center, just have a tendency to do so.
2006 Camry LE Special Edition
2007 Camry JBL speakers in a 2002 XLE. sundarpn 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-31-2007 10:34 PM
WTB: Power Steering Pressure and Return Lines still Car parts for trade or wanted parts 0 08-27-2007 02:37 PM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
Overly powerful steering on 93 camry xle v6 acitydweller 3rd & 4th Generation (1992–1996 & 1997–2001) 9 12-22-2006 08:35 PM
using Mobil 1 ATF as Power Steering Fluid for 2002 Camry 2002Camry 5th & 6th Generation (2002-2006 & 2007-2011) 0 05-12-2003 10:10 AM
