Tires Pressure in Camry-> 2004 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2007, 07:49 AM   #1 (permalink)
View szymbura's Photo Gallery
European Union Tires Pressure in Camry-> 2004
I'm first time here so forgive some misunderstandings. Actually I signed in because of my aunt who bought T.Camry excatly in U.S.A. and imported it to the Europe. What is the right tire pressure for this car? For front and rear?
Thanks for help....
szymbura is offline   Reply With Quote
Old 09-16-2007, 09:50 AM   #2 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
32PSI i believe? rtfm ?? or look on your door jamb ...
CamrySExxx is offline   Reply With Quote
Old 09-16-2007, 01:50 PM   #3 (permalink)
ok , thanks
Old 09-16-2007, 10:36 PM   #4 (permalink)
View ucisilentbob's Photo Gallery
The Dealer says it's 29 psi. I inflate to 32 psi for better mileage.
2007 SE V6 2GR-FE
Magnetic Gray Metallic
2004 LE V6 1MZ-FE
Stratosphere Mica
ucisilentbob is offline   Reply With Quote
Old 09-16-2007, 10:57 PM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
There should be a sticker on the driver door or on the frame for the driver door. It will indicate the recommended tire pressure.
It might only be listed in PSI if you imported it from USA so you may need do convert to kPa.
2007 Camry 2.4L 5M
Old 09-16-2007, 11:54 PM   #6 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
you could always look up the us manual corresponding to your year. True, over inflation does give better mileage, but it always creates a harsher ride, and higher probability of it popping to severe impacts.
desentrix is offline   Reply With Quote
Old 09-17-2007, 02:20 AM   #7 (permalink)
affirmative
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
2004 highlander low tire pressure indicator laputagd 1st Generation (2001–2007) 10 03-19-2007 12:36 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
2004 Camry RS3200 Plus Security System LSFT 5th & 6th Generation (2002-2006 & 2007-2011) 0 08-09-2006 02:58 PM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
