Reprogramming the panic mode - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2007, 09:39 AM   #1 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
For the first time since i've had my car, I used the panic button, but only to scare one of my friends that was walking by.
But I noticed that it flashes the low-beam headlights when it's going off, now normally it's not a problem, but since I have HID's I know it's not good to be flashing them off and on. So I was wondering if there was a way to reprogram what the panic button does, similarly to how you can reprogram the automatic door locks and such.
geoff5093 is offline   Reply With Quote
Old 09-20-2007, 09:34 PM   #2 (permalink)
geoff5093's Avatar
Hmmm... so no one knows?
Old 09-20-2007, 09:44 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
My Service Manual says NO, guess you couldn't find yours..........
Old 09-20-2007, 09:49 PM   #4 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
LMAO!!
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 09-21-2007, 06:25 AM   #5 (permalink)
geoff5093's Avatar
lol, I knew you were going to respond at some point. I've read the manual over a few times, but I remember hearing about ways to reprogram things such as the door locks that I thought there would be a way to do so with the panic mode.
Old 09-22-2007, 06:32 PM   #6 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
Gen5
Put the hid lights on a diff circuit.. and a seperate switch. and put the regular lo beam switch onto the high beams?
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 09-22-2007, 06:46 PM   #7 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
That sounds like a giant hassle. What would be the point? So now you need to flip a seperate switch to turn on the low beams... but if you do that, your gauge cluster won't light up... so you need to turn on the headlamp switch anyway... doing that will activate the high beams. If you put it on the parking lights, it'll activate the DRLs.
I've dealt with the same problem. There's no real solution to this other than to not use the Panic button. Hell, aside from accidentally, I've never had a use for it.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 09-22-2007, 09:52 PM   #8 (permalink)
I've never felt like one incident or two of your alarm going off or panic mode going on will really be that bad for your HID. Some cars that come OEM with HID have alarms that cause the headlights to blink off and on. So I figure it's just one of those cases where as long as you don't put your ballasts under constant abuse, they will be fine. That is my guess.
Old 09-22-2007, 10:50 PM   #9 (permalink)
geoff5093's Avatar
I dont use it often at all, i've only used it once. I just found it pretty hilarious when my friends were near my car and I pressed it, just to see them jump, haha
I can live with not using it, I just wanted to know if there was a way to work around it.
2000 Camry Vent Mode cougar 3rd & 4th Generation (1992–1996 & 1997–2001) 3 04-26-2010 05:26 PM
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
Radio Error Message 06 Sport Taco 2nd Generation (2005+) 9 09-10-2007 08:45 PM
Way to tell if ECU is in closed loop mode 97camryman Camry & Solara Lounge 0 09-20-2005 10:50 AM
Factory Alarm Programing Mousiee Camry & Solara Lounge 15 06-29-2005 07:13 AM
