Originally Posted by Frank20
^ Yes, those are exactly what I am talking about. Who makes those ones? The project kics look just like those. How exactly do those work though, can someone explain them a bit, I am staring at them and trying to figure it out but maybe someone can explain it a little better. The only problem is how do I know what size spacer to get?
Frank20,
Here is the link to the website.
http://www.ezaccessory.com/Wheel_Ada.../5450-5450.htm
These wheel adapter can be use as Pattern Conversion or Non-Pattern Conversion.
In your case, it would be the Non-Patttern Converstion meaning same 5x114.3 to 5x114.3 you just simple want to push the wheels out toward the edge to the wheel well.
Installation is just what you see from the picture. You just place the adapter onto your car's hub then tighten it up using the 5 lug nuts that you would normally tighten your wheels. After that, you put your wheels onto the new adapter. That's it.
Edit: How much you want to push out depend on the thickness you choose when order it. This website only have 1" and up. But I know that ichiba also has adapter ranging from 5mm to 25 mm (which close to 1").
Before you ask, here is the link
www.ichibausa.com
How To Measure?
The widest point of your tire and wheel combination is usually the outside diameter of the tire sidewall. Using a ruler with the straight edge flush with the face of the tire, measure the gap between the outer face of the tire to the inside lip of the fender as shown in the diagram. This will determine the thickness of the spacer you will need. 5MM = 0.197 INCH / 8MM = 0.313 INCH
10MM = 0.393 INCH / 12MM = 0.473 INCH
15MM = 0.590 INCH / 20MM = 0.787 INCH
25MM = 0.983 INCH
