Please Help with 2005 CAMRY LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2007, 02:21 PM   #1 (permalink)
View akkua123's Photo Gallery
Gen5 Please Help with 2005 CAMRY LE
Hi
I am a newbee in this forum.I bought a 2005 CAMRY from a delear before 4 months when it was 37,222 Miles from a TOYOTA Dealer. Before 3 weeks I felt that I am applying more gas for accelaration than normal from a STOP position.I thought it was because of Oil and I went to another TOYOTA service centre and did an Oil change .But I still have the issue persists .The car is now on 39,634Miles.If some one can guide me how to proceed.
Thanks in advance
Veetil
akkua123 is offline   Reply With Quote
Old 09-17-2007, 02:49 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
I assume you have an I4 engine. If you have no service records on this car, I would remove the valve cover and look for sludging on the valve train, and make >>absolutely certain<< that the passage which connects to the PVC valve is clear and open. In my experience, excessive sludge will cause the engine to lose power by clogging the pvc passage and forcing oil into the cylinders, and not knowing the engine's history, this is a good point to start.
gdanaher is offline   Reply With Quote
Old 09-17-2007, 03:06 PM   #3 (permalink)
Thank you gdanaher for your quick response.Yes ..mine is a V4 Engine and I dont have any service records of the vehicle and I am very sorry to say I dont know much about AUTOMOTIVE MECHANISM... If it is something related to computers or network I can handle.Is it a good option to take it to the same dealer as the vehicle is still under warranty/I bought extended warrany also
Old 09-17-2007, 03:12 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I doubt that sludge would cause a sudden change in the operation of your I4 (inline 4 cylinder) engine.
If the check engine light isn't on and there aren't any other indications that there is actually a problem, there probably isn't.
You vehicle is adaptive also. It does adjust to your driving habits. You could try removing the battery ground cable for a few minutes and then reattach it. The cars computer will be reset and will clear the adaptive memory and you'll start fresh. Maybe there is a conflict between your driving style and the previous owner's driving style.
2006 Camry LE Special Edition
Old 09-17-2007, 03:59 PM   #5 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
just wondering, do we have a list of camry's that are adaptive? I wanted to know -- my car drives almost differently now since I swapped batteries out ? thanks!
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 09-17-2007, 08:58 PM   #6 (permalink)
TRD VVTi's Avatar
Gen5
Basically from '96 on up has some sort of adaptive capability. Because of the OBDII emissions demands cars had to adapt to componants degrading and keep the car functioning properly without setting the MIL (check engine light).
I'm not sure in what years the amounts of the adaptive features were enhancing other things such as transmission shift points, pressures, etc. It's been many years though.
Old 09-18-2007, 11:38 AM   #7 (permalink)
Maven
gdanaher's Avatar
TRD, fwiw, my solution/suggestion came from personal experience with a '99 which had exhibited sludging. The primary problem was that the venting inside the valve cover became clogged and from there it was all down hill. PVC valve was just fine and exhibited no crud at all. Once I was able to blow out the clog in the cover, things began to improve. Never had an engine light come on during the entire process, but most assuredly the power fell off to the point I didn't know if it was going to make some hills.
Old 09-18-2007, 11:55 AM   #8 (permalink)
TRD VVTi's Avatar
Gen5
I didn't doubt your particular experience.
I'm just saying that I doubt the engine would suddenly lose power the way it was described due to sludge or gel with the information provided. Usually it's a gradual performance lose. A change in performance after 2,000 miles isn't likely. The car probably had a fresh oil change when purchased, which helps me to exclude your theory.
Gelling or sludge doesn't usually cause the MIL to illuminate either, I already know that. I was referring to other possible driveability problems.
Throwing out ideas is the name of the game. I was just sharing my opinion.
Old 09-18-2007, 04:00 PM   #9 (permalink)
Maven
gdanaher's Avatar
My problem occurred in the same mileage range btw. Anyway, without a MIL it is hard to diagnose without more information, and since the guy hasn't had it long enough to know all of the quirks, this is a challenge.
-very low tire pressure
-brake pads dragging excessively
-trunk full of junk that weighs it down
-dirty air filter
-dirty throttle body
-butterfly valve gummed up and sticking
-heavy on the carbon in cylinders
Try some RXP which is supposed to break up carbon deposits and improve emissions.
-catalytic converter clogged?
-any kind of back pressure will kill horsepower.
Old 09-18-2007, 05:27 PM   #10 (permalink)
Mine is a clean car and I try to keep very clean.I am going to take all you experienced guys sugession and monitor all the parts you told. thanks 'gdanaher' and 'TRD VVTi'
2005 CAMRY LE i4 desi_prodigy Vehicles 1 08-23-2006 07:21 AM
2005 camry le waterleak into cabin ebiggs264 5th & 6th Generation (2002-2006 & 2007-2011) 2 10-15-2005 09:47 PM
My new 2005 Camry LE! Cyberhwk Show & Share 14 03-10-2005 12:02 AM
What size speaker in 2005 Camry LE?!?! Cyberhwk Audio, Video, and Security - Tech 6 01-27-2005 08:46 AM
