Armrest cover keeps popping up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2007, 09:21 PM   #1 (permalink)
View helloworld's Photo Gallery
Gen5 Armrest cover keeps popping up
Hello,
My 2003 Camry LE starts to have an annoying problem: the armrest cover cannot be locked securely and keeps popping up every 2 minutes Apparantly the latch on the cover does not fully engage the hole on the plastic shelf piece below the cover. I took off the cover and found that the latch seems working fine but its position does not match the hole. All the screws are fixed so there is nothing to adjust. What is the problem? Any suggestion?
Thank you.
helloworld is offline   Reply With Quote
Old 09-19-2007, 09:46 PM   #2 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
don't know what the problem is, but you could try using more force to close the armrest. or, make the latch hole larger, so that the latch can catch it better.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 09-19-2007, 09:59 PM   #3 (permalink)
View clarkgrizwald's Photo Gallery
had this exact same problem after installing the ir sensor for the swi-x in the armrest. know what i did to fix it? i cut a small strip of electrical tape narrow enough to fit in there and wrapped it around the little bar twice. just enought to make the latch things diamater big enough to secure when you close it. its worked now for 2 months no problem.
edit: it also made the 'click' when you close the armrest have a 'soft' feel to it. it seems more luxurious now!
clarkgrizwald is offline   Reply With Quote
Old 09-20-2007, 02:24 AM   #4 (permalink)
View TCLEshovon's Photo Gallery
damn..I had the same problem and did exactly what clarkgrizwald did...going on like 4 months now and no problems from the armrest!!
TCLEshovon is offline   Reply With Quote
Old 09-20-2007, 11:20 AM   #5 (permalink)
& JustAnotherCamry
View JustAnotherAsian's Photo Gallery
LMAO. i had the same annoying problem a few months ago! but somehow, it cured itself- probably cuz i kept banging the armrest locked due to frustration. LOL.
but seriously, i think it was also caused by temperature- i used to park it outside in the cold & hot everyday without driving the car for days in a row when i was dorming. it's garaged every once in a while now. ever since i stopped dorming, i never had the problem.
it used to be really annoying though. popping out in the middle of driving almost every day.
JustAnotherAsian is offline   Reply With Quote
Old 09-20-2007, 09:42 PM   #6 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
I probably won't be laughing when it starts happening to me but hey.....for now, it's funny.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 09-20-2007, 09:50 PM   #7 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
duct tape!
CamrySExxx is offline   Reply With Quote
Old 09-21-2007, 11:47 AM   #8 (permalink)
Thank you for all your suggestions! Tape sounds like a good temporary fix. But is there any permanent solution? If nothing works, I may want to change to a sliding armrest. Does that work?
Anybody have a pace edwards roll top cover? brianullig 2nd Generation (2005+) 11 04-30-2007 10:10 PM
trouble with engine cover bolts for 3vzfe ryuji16 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-05-2006 06:05 PM
2006 Tacoma Tonneau Cover texassports1 2nd Generation (2005+) 2 08-04-2006 03:19 PM
Removing Gen 2 Valve cover? PoR2GeEzCamry 1st & 2nd Generation (1983–1986 & 1987-1991) 3 03-20-2005 10:53 PM
RAV4 Upper Timing Belt Cover Skinned Knuckle Hardcore Tech and Competition 0 02-05-2004 09:54 AM
