Glass Odometer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2007, 07:37 PM   #1 (permalink)
View XPS9000's Photo Gallery
Gen5 Glass Odometer
I was wondering how would u take out the exisitng glass surrounding the odometer and the glass covering the place where u shift gears??? The reason I am planning to replace it is because there is bubbles popping out in the glass and I cannot seem to wipe it out with windex or water
XPS9000 is offline   Reply With Quote
Old 09-21-2007, 09:16 PM   #2 (permalink)
Gameroom cash: $255930
View LE05's Photo Gallery
pretty sure toyota doesn't use glass for the trim anywhere, except for the windows. are you referring to the plastic covering the gauges and the gear shift trim? if you are, refer to the manuals stickied here:
http://www.toyotanation.com/forum/t132391.html
these are the full repair manuals, you'll be able to find instructions on how to take those things out.
FYI, for future cleaning of said areas, i wouldn't use windex. its a bit harsh on soft plastic over time.... i would just use warm water with some mild soap.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 09-21-2007, 10:12 PM   #3 (permalink)
Gen5
ya I meant the plastic covering the odometer and gear shift trim. I was looking through the manuals and I could not find the right one. Could u help me out in finding it and and send me the exact link??
Old 09-21-2007, 10:25 PM   #4 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $133432
View Yazovets's Photo Gallery
Vodka works on anything wonderfully!
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 09-22-2007, 03:45 AM   #5 (permalink)
View clarkgrizwald's Photo Gallery
including your girls tits!
clarkgrizwald is offline   Reply With Quote
Old 09-22-2007, 03:56 AM   #6 (permalink)
Bootyologist
View 2k4CamThrilla's Photo Gallery
That's all i have to say. I have that same problem with the plastic thats around my odometer.
www.myspace.com/djkraz
2009 Toyota Camry SE-(BLK LEATHER,NAVI,Debaged,Blue LED shifter mod,20% Tint)
2004 Toyota Camry LE(SOLD)
1989 Ford Tempo AWD(SOLD)
2k4CamThrilla is offline   Reply With Quote
Old 09-22-2007, 11:19 AM   #7 (permalink)
Gen5
Do u know of any cleaning solutions that will get rid of it?? Does ur plastic odometer casing have scratches?? I was stupid and the first time I tried get rid of the dust I used a paper towel after that it scratched everything. Do u think air compressors work wonders for those
Old 09-22-2007, 02:15 PM   #8 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
Use a mircofiber towel only to clean. Bubbles in the plastic? That shouldn't be possible. Are you getting crazing on the surface? Anything happening on the surface can be polished out with a good paint polish and some elbow grease. Again, only use mircofiber.
Rapid Roy is offline   Reply With Quote
Old 09-22-2007, 03:02 PM   #9 (permalink)
Gen5
I did buy a microfiber towel and it just made it worse with a bunch of scratches
Old 09-22-2007, 03:17 PM   #10 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Good idea, but I have no girl.
Old 09-23-2007, 01:46 AM   #11 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Meguires makes a good product called PlasticX (or something like that). It gets scratches out of plastic easily. I've used it on several thinks including window tint.
You would think Toyota would use a harder plastic that doesn't scratch as easy. If you fart in the car that plastic gets scratched...
2006 Camry LE Special Edition
Old 09-23-2007, 02:01 PM   #12 (permalink)
View kenny1773's Photo Gallery
If it is in the surface, the Novus 3 step system WILL take it out if you rub long enough
http://detailing4less.com/novus-plas...FTaoGgodYhRbNg
#3 is pretty abrasive and then #1 isn't abrasive at all, strickly a polish, #2 is in beween
I have take fairly large scraches out of motocycle helmet visors with this stuff, it just takes a while and of course a micro fiber towel.
kenny1773 is offline   Reply With Quote
Old 09-23-2007, 05:47 PM   #13 (permalink)
Bootyologist
It's still there. I haven't touched it. Compressor would help you at all.
Newbie here: Getting 95 camry today! Mjakaz95LE Introduce Yourself Here 24 04-21-2009 07:06 AM
How to turn the odometer forward luiscolorado 3rd & 4th Generation (1992–1996 & 1997–2001) 8 01-15-2007 02:02 PM
HELP! Replaced Window Regulator and glass stops 3/4 way up? How do I adjust the Glass green94camry Camry & Solara Lounge 17 07-11-2006 09:49 PM
Replacing outside mirror glass ln '98 Sienna clem24 1st Generation (1998-2003) 0 01-15-2005 08:01 PM
