Original battery in '02 Camry - replace? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2007, 12:25 AM   #1 (permalink)
etc
View etc's Photo Gallery
Original battery in '02 Camry - replace it?
It's Panasonic, the car was made on 05/02
etc is offline   Reply With Quote
Old 09-24-2007, 12:28 AM   #2 (permalink)
View ucisilentbob's Photo Gallery
Wow, you got good life out of your Original Car Battery. My Battery went out this past summer, so right around 3 years for me before i had to replace.
2007 SE V6 2GR-FE
Magnetic Gray Metallic
2004 LE V6 1MZ-FE
Stratosphere Mica
ucisilentbob is offline   Reply With Quote
Old 09-24-2007, 01:39 AM   #3 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
Are your having issues with the battery? Is the engine cranking slowly? If not, I say just keep on going. My wifes 02 I4 still has the original battery in it and its still going strong.
Rapid Roy is offline   Reply With Quote
Old 09-24-2007, 07:14 AM   #4 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
my 02 still has original battery and have had a stereo in it for 2+yrs.
johnnyzee is offline   Reply With Quote
Old 09-24-2007, 07:27 AM   #5 (permalink)
etc
It works well, but I just wanted to be ready.
What's a good replacement for it?
Like a model number, cranking amps, and where to find it, advance auto/Walmart/Sears/whatever.
Old 09-24-2007, 08:57 AM   #6 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $318510
View gdanaher's Photo Gallery
--I've had a brand new battery fail 4 months after installation
--I've had a brand new battery last over 7 years. Sold the car before the original battery ever failed
--Let the car sit for awhile and using your volt meter check the standing voltage. Should be at least 12.5. Compare to another car with a fresh battery if in doubt.
--Since you live in an area that gets cold the odds are that one morning you will find it sluggish to start and then it is time to replace.
It depends on a number of factors. Own a battery charger that you can use if you need an emergency boost one morning? Own a second car you can use for a jump? Have Auto Club insurance? Don't bother wasting your money. If not and feeling a little insecure? Get a new battery.
Now, what kind? As a general rule, they are almost all about the same with different labels. Since there is relatively little difference in price between a 3 year and a 6 year battery, get what you can best afford and know they will all fail at about the same time. I used to buy Sears Diehard and got out of that rut. They would fail at 24 months and I would have to buy another at their pro-rated price to get a new battery. I learned. They weren't any better than the cheapies at Pep Boys and Walmart. Today my preference is for Pep Boys because the store is walking distance if I need to hoof it. Take a look at warranties and pick one. There won't be $5 difference between all of them. Batteries are a commodity item like milk and bread.
gdanaher is offline   Reply With Quote
Old 09-24-2007, 09:06 AM   #7 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
if it works dont replace it.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 09-24-2007, 09:21 AM   #8 (permalink)
I work with reTRDs
manaburrn's Avatar
View manaburrn's Photo Gallery
My 02 battery went out last week
manaburrn is offline   Reply With Quote
Old 09-24-2007, 11:04 AM   #9 (permalink)
View Aceventura9586's Photo Gallery
I replaced my 03 battery cuz I wanted to. I got a bigger one with a higher CCA #. Mainly cuz I have several things that draw significant power when I start my car.
Aceventura9586 is offline   Reply With Quote
Old 09-24-2007, 11:10 AM   #10 (permalink)
johnnyzee's Avatar
wow, what a story
Old 09-24-2007, 11:43 AM   #11 (permalink)
View Mike Murrell's Photo Gallery
The batteries made today do not seem to last as long as they used to. Likely all of the electronic "memories" today's cars are loaded with.
Your 5 yr. old battery could last another yr. and it could die tomorrow.
You definitely did good.
My stepson's Accord had a Panasonic battery and it too lasted quite a long time.
You might consider looking around for another Panasonic when the time comes.
Mike Murrell is offline   Reply With Quote
Old 09-24-2007, 12:28 PM   #12 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
ditto -- and love the screen name -- ever play MTG?
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 09-24-2007, 01:49 PM   #13 (permalink)
Maven
gdanaher's Avatar
Nobody really answered the question about cold cranking amps. You will need to buy a battery which fits. Look for the group # on the top of the old battery. 24F I think. The posts should be in the correct position with the correct polarity as the old battery. You will notice, looking at labels, that the longer the warranty, the more CCA it will claim. Buy the most expensive battery and you will likely get the battery with the largest CCA numbers as well. Lead-acid batteries begin to die the day they are made, so to have a long warranty they need to build in more initial capacity and this is done by varying the thickness of the case and the internal plates. On an average fall day it doesn't take much to start a car and the battery is only being taxed for 3-4 seconds. The real test comes when the weather is colder, the engine is tighter and presents more resistance to turning, and the temp has dropped the battery capacity.
Batteries are cheap. If you are getting nervous about the battery, go and buy a new battery. You shouldn't angst about a car battery. Kidney transplant yes but not a battery.
Old 09-24-2007, 01:57 PM   #14 (permalink)
I work with reTRDs
manaburrn's Avatar
get a gel cell
Old 09-24-2007, 03:38 PM   #15 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
The average battery life is four years.
I have had great luck with and recommend Optima batteries.
You're better safe than sorry when it comes to batteries. It WILL fail, why wait until you are inconvienced by it's failure? If you make it four years, you're lucky. You could go more but why chance it? It's not worth the gamble. If you buy it this year or next, it won't save you any money either way.
2006 Camry LE Special Edition
Personal Camry Websites - POST HERE Silver Streak Camry & Solara Lounge 193 08-03-2011 12:56 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 11:55 PM
98 Camry LE Battery jmcolwell 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-08-2006 06:57 PM
Need To boards, Need Help with someone with 02 camry service manual? Streetglower 5th & 6th Generation (2002-2006 & 2007-2011) 3 07-01-2005 09:34 AM
Stereo Activation Key Required??? (replace battery) spup345 Camry & Solara Lounge 6 06-15-2005 04:25 PM
