Replace radio, 2002 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2007, 05:51 AM   #1 (permalink)
View CarlDombek's Photo Gallery
Here's how it worked on mine:
1) Insert a putty knife or a broad-blade screwdriver at the bottom of the panel with the climate controls. Gently pry that forward (it hinges at the top).
2) With that loose, grab the bezel that surrounds the radio and pull it straight toward you.
3) The top piece with the outside temp readout will still be attached. Either unplug the display or unscrew the panel to allow you to set the bezel aside and get it out of your way.
4) There are four 10mm bolts holding the radio in. Remove those, using at least a 6" extension bar on your ratchet (which you will need to reach the back two bolts).
5) Slide the radio out, and unhook the two plugs and the antenna lead in the back.
6) Unscrew the four screws that hold on each side bracket. Note whether the longer fingers were on the top or bottom for reinstallation.
7) Installation is in reverse order.
I hope you find this helpful.
CarlDombek is offline   Reply With Quote
Old 09-24-2007, 11:23 AM   #2 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
hey man, cool of you to drop that down on a thread.
johnnyzee is offline   Reply With Quote
Old 09-24-2007, 02:07 PM   #3 (permalink)
View Camry5genrocks's Photo Gallery
Thanks for the thread
Camry5genrocks is offline   Reply With Quote
Old 09-24-2007, 02:43 PM   #4 (permalink)
Bootyologist
View 2k4CamThrilla's Photo Gallery
If I could give you props I would for trying...
www.myspace.com/djkraz
2009 Toyota Camry SE-(BLK LEATHER,NAVI,Debaged,Blue LED shifter mod,20% Tint)
2004 Toyota Camry LE(SOLD)
1989 Ford Tempo AWD(SOLD)
2k4CamThrilla is offline   Reply With Quote
2002 Camry Radio Removal and Install help. humuhumupukapuka Audio, Video, and Security - Tech 11 12-11-2009 01:24 AM
2002 solara - radio question ljn21 Solara 1 12-09-2006 06:05 PM
97 Camry XLE radio wiring dman55088 3rd & 4th Generation (1992–1996 & 1997–2001) 5 09-30-2006 05:53 PM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 04:43 AM
