Oh, and if anybody wants to do this, it's easy.
Jack up one side, put a jack stand underneath
Take the jack, collapse it completely, turn it upside down and shove it into the spring sideways, like a wedge
Jack an opening into the spring
Decide ahead of time how much boost you want, and put the boosters together in that height (you can always change it). Use a vise - it will help you torque the botls down nice and tight.
You will probably need to trim the bolts (they will hit the other coils, I took an inch off each) using a grinder or cutoff disc
position them and then collapse the jack
Lower the car and give it a day for everything to settle
Adjust by doing everything in reverse then forward again.
It's really easy, just make sure the bolts don't touch a spring seat (top or bottom) - the bolts should point to the middle of the spring.
Originally Posted by TRD VVTi
You car looks like ass!!!!
