Problems removing rear drum brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2007, 10:11 PM   #1 (permalink)
etc
View etc's Photo Gallery
The manual says if the hub does not come off, to remove the rubber plug and adjust the wheel.
However, there is nothing under the rubber plug at all. What I am missing?
This is 02 Camry.
etc is offline   Reply With Quote
Old 09-24-2007, 10:15 PM   #2 (permalink)
The Connoisseur
CharmCityES's Avatar
make sure your parking brake is off first of all....ive seen too many people have an issue with this because of the parking brake being on
next, take a plastic mallet and wail away at the drum....it should knock it loose enough to pull styraight off, and it wont damage the drum at all! its the method i use and that i was taught in my toyota technical training
The "Executive Sedan"
Old 09-24-2007, 10:38 PM   #3 (permalink)
etc
Yes, the parking brake is off, and yes, I've banged on the wheel with a rubber hammer long enough to get frustrated. There has to be something else.
What's that rubber plug for, if there is just metal under it?
Old 09-24-2007, 10:41 PM   #4 (permalink)
The Connoisseur
youre supposed to be able to insert some type of rounded tool like a punch in there and hit it with a hammer to dislodge the drum....ive never had one that a few mallet strokes couldnet take care of...
also, try spraying wd 40 or something around the edges to loosen it up
Old 09-24-2007, 10:45 PM   #5 (permalink)
etc
Hm, maybe I should try it. But it's solid steel behind that plug. I was expecting to find something to adjust.
Also, I did spray the entire area with PB Blaster, the ultimate spray for rust stuff. (Ideally should let it soak for a day or two) No luck after 15 mins of waiting however.
Did you see what the Haynes/ Factory Service Manual recommends? I've read and re-read the stupid thing and just don't get it. I think you are supposed to adjust the brake shoes by removing that plug and rotating something there. Yes/no?
Old 09-24-2007, 10:46 PM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Whoever installed the brake drum didn't align it properly with the hole in the hub. That's why you are seeing the hub through the hole.
Tap the drum with a metal hammer between the lugstuds.
If that doesn't work thread bolts into the drum in the holes provided and evenly tighten them.
2006 Camry LE Special Edition
Old 09-24-2007, 10:47 PM   #7 (permalink)
The Connoisseur
i havent heard of that....to adjust the shoes i have to take the drum off and use the star wheel in between the springs and some prescise measurements to make adjustments....thats just me tho
Old 09-24-2007, 10:53 PM   #8 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
+1 on threading bolts into the drum. It will pop the drum right off.
Rapid Roy is offline   Reply With Quote
Old 09-24-2007, 10:54 PM   #9 (permalink)
TRD VVTi's Avatar
Gen5
You don't have to take the drum off. That's what the access hole is for. Of course, if you don't line up the drum properly it can't be used properly.
It really doesn't matter if you adjust it through the hole or by taking the drum off.
I've also never heard of anyone taking precise measurements when adjusting drum brakes. Could you explain this procedure that you use, CorCamrySE?
Old 09-24-2007, 11:26 PM   #10 (permalink)
View toyomoho's Photo Gallery
Ditto on the hole in the hub not being aligned with the hole in the drum. As the hub is currently installed you do not have access to this mechanism to retract the shoes.
Ditto on the two bolt holes on the drum face. Find two metric bolts that are of the same thread size and diameter. Insert them into the holes and use them to push against the hub and move the drum away from it.
If you have access to a torch, heat the area around the hub. The drum should pop loose.
If you use the hammer method, place a block of wood against the drum and hit this to deaden the hammer blows.
Old 09-25-2007, 06:54 AM   #11 (permalink)
etc
OK, that all makes sense.
What size bolts can I use?
Yes, I can use a torch also, which area do I heat? In middle or around the circumference?
Old 09-25-2007, 11:42 AM   #12 (permalink)
TRD VVTi's Avatar
Gen5
Sorry, I can't remember the size.
Don't use a torch at all. You will warp the metal.
You don't need to use wood to insulate the hammer from the drum either. The object isn't to beat the crap out of the drum but break the drum free from corrosion. Hitting the metal between the lugstuds won't hurt anything. The hub is behind the drum in that area. The vibrations will help work the drum free.
Old 09-29-2007, 08:46 AM   #13 (permalink)
View marc780's Photo Gallery
Use the bolt holes like they said. If that doesnt work for some reason, try a 3 jawed puller tool
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
disc brakes to replace drum brakes in the rear possible? 2006matrix 1st Generation (2003-2008) 0 12-01-2006 10:56 AM
Need help on a few question about upgrading rear brakes speedy_speed_bo 3rd & 4th Generation (1992–1996 & 1997–2001) 1 10-15-2006 02:27 PM
Problems with the rear suspension. just2asian Camry & Solara Lounge 13 02-22-2006 11:41 PM
Rear brakes conversion (drum to disk) _Frank_ Celica Forum 6 01-05-2006 04:16 PM
