Aligning a headlight 2004 Camry le - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2007, 06:56 PM   #1 (permalink)
View dusty768's Photo Gallery
How do you realign a headlight on a 2004 Camry LE?
dusty768 is offline   Reply With Quote
Old 09-25-2007, 07:46 PM   #2 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
There's a screw in the back. Use a socket wrench. I think clockwise raises the headlights and counterclockwise lowers the headlight. Good luck.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 09-25-2007, 08:09 PM   #3 (permalink)
Import Tuning
camry man68's Avatar
View camry man68's Photo Gallery
make sure you read your manual to get the proper alignments otherwise you wont get good vision at night
camry man68 is offline   Reply With Quote
Old 09-25-2007, 08:23 PM   #4 (permalink)
The Connoisseur
CharmCityES's Avatar
line your car up with a wall at dusk, and turn your headlights on....there is a small screw in the back of the headlight, and turning it adjusts the height of the beam pattern....use the wall as a guide and set the lights so they provide optimum visability....aslo be sure and check the manual for specs so you get it right the first time
better safe than sorry
The "Executive Sedan"
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
2004 Camry RS3200 Plus Security System LSFT 5th & 6th Generation (2002-2006 & 2007-2011) 0 08-09-2006 02:58 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
Seperating 02-04 Camry headlights italia490 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-17-2004 12:18 PM
mod a 99 camry le ? Gachinto General Discussion 2 12-02-2004 07:40 PM
