07 Camry LE V6, transmission/hot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2007, 07:22 AM   #1 (permalink)
View DDL24's Photo Gallery
Have been driving the new LE for the past two months. Bought it 8/1/07. about two thousand miles now. My previous car was a 2005 Audi S4 with 6speed manual, just so you know my frame of reference.
I swithched to the Camry mainly for my daily commute (27miles one way)in DC area which it does very well, comfortable, economical, stress free and reasonably powerful and surprisingly competent in handling.
The 6speed automatic in the Camry is definitely the least smoothest automatic I have experienced, from low grade rental cars to Ford to C/E/M class Mercedes to LS430. It wasn't as bad initially but as mileage rolls on, I have noticed deterioration in shifing quality, not much as surge but more of abrupt shifting in low speed, specially when just start a trip after overnight parking. But I already read about all those before I bought the car so I am not surprised. I will just wait till the first oil change and request them to re flash and see how it works out and report back here.
One thing I am a little surprised is the following.
after driving for awhile, the center consol surface area between where tranmission shifter and the little storage cube before the armrest, can get pretty warm. Is that normal? Not fresh cup of coffee hot but very warm to the touch. Thanks.
DDL24 is offline   Reply With Quote
Old 09-27-2007, 08:46 AM   #2 (permalink)
View Aceventura9586's Photo Gallery
For the shifting you can try some of the LucasOil products. They make a fluid for ur trans that smooths out the shifting actually rather well. I use it in my car and it helps. Check that out for the tranny, and about the heat, I have no clue what that's all about. I'm still learning on the new camrys. Someone else chime in please
Aceventura9586 is offline   Reply With Quote
Old 09-27-2007, 08:53 AM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Yes, it's normal.
No, don't install Lucas transmission products into the transmission.
2006 Camry LE Special Edition
Old 09-27-2007, 10:01 AM   #4 (permalink)
What's wrong with the lucas transmission products? Given I've only done it once.
Old 09-27-2007, 10:18 AM   #5 (permalink)
TRD VVTi's Avatar
Gen5
Call Toyota and ask them. They specifically state that no additives should be added to the fluid and that no solvents should be run through the transmission.
Lucas doesn't make any transmission fluids or additives that are Type T-IV approved.
Old 09-27-2007, 10:19 AM   #6 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I thought the Gen 6 V6 models had a closed transmission system, where you can't add any fluid to it by normal methods?
geoff5093 is offline   Reply With Quote
Old 09-27-2007, 10:21 AM   #7 (permalink)
it is what it is
akira751's Avatar
View akira751's Photo Gallery
Gen6
I have none of those issues. My trans runs just fine.
07 Camry SE V6, Nav Mag Grey,18" Nex-0 gun metal, Trd Springs,K&N Typhoon Intake
http://www.cardomain.com/ride/2475669
akira751 is offline   Reply With Quote
Old 09-27-2007, 10:22 AM   #8 (permalink)
TRD VVTi's Avatar
Gen5
You can add transmission fluid by normal methods. You just can't check the fluid with a dipstick. There have been several posts regarding this in the past. If you do a search I know that you will find at least 2 threads.
Old 09-27-2007, 10:37 AM   #9 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Work generates heat and thankfully your tranny is working...............
Old 09-27-2007, 10:59 AM   #10 (permalink)
geoff5093's Avatar
Oh gotcha, I just remember the service guy at the dealer was saying that the transmission was a "closed" system. Now that I think about it, I remember a few posts showing how to add fluid to the transmission.
Old 09-27-2007, 12:41 PM   #11 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
my damn camry shifts like a sling shot from 1st to 2nd! all the time.
i think it just the way it is.
car runs fine.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 09-27-2007, 02:12 PM   #12 (permalink)
View Camry5genrocks's Photo Gallery
First the 07s are not using Type T-IV fluid. Beginning for the 2007 model year, several Toyota vehicle transmissions (Camry, Avalon, Tundra, 4-Runner, Prius, & Highlander Hybrid) have "WS" transmission fluid. There is not a recommended drain interval for this fluid at this time. Don't use any Lucas oil in your transmission. How will it interact with WS fluid? Wait until the Powertrain Warranty is up and then start experimenting with your Camry. Toyota can deny you warranty work, if they found out that you added an additive to your tranny.
Camry5genrocks is offline   Reply With Quote
Old 09-27-2007, 09:21 PM   #13 (permalink)
silverSEV6's Avatar
View silverSEV6's Photo Gallery
Ok. Enough about the fluids and oils. What about that warm spot by the shifter? I have it too. And its not everywhere, its only in one little particular spot.
Camry SE V6 Silver | Dark Charcoal leather with heated seats | Moonroof | JBL stereo with 6-dics changer | Auto-dimmer with compass
MODS: 30% tint all around | Moved SE emblem to the upper-right corner | Blue LED's on steering wheel and shifter | K&N Drop-In air filter | White LED lights inside
silverSEV6 is offline   Reply With Quote
Old 09-27-2007, 09:55 PM   #14 (permalink)
View vinniemak's Photo Gallery
car runs fine.
Carlo$ get the TSB # EG036-07 I4 ECM Calibration done under warranty...you'll be shocked how smooth the tranny shifts...
vinniemak is offline   Reply With Quote
Old 09-28-2007, 06:10 AM   #15 (permalink)
View beejay21k's Photo Gallery
I've noticed the warm spot on the console too. It's very small, pretty much in the lower left corner, just below the P-R-N-4-D... lights. I just assumed it was something to do with the circuit for the lights. Anybody have any ideas?
2007 Camry LE
16" Alloy Wheels | Moonroof | Sirius
beejay21k is offline   Reply With Quote
How Many Toyotas Went Through Your Family? hmong337 General Discussion 45 09-10-2010 01:11 AM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Bought '07 Camry LE V6 last night Sandiana 5th & 6th Generation (2002-2006 & 2007-2011) 2 06-01-2006 09:36 PM
92-96 Camry LE V6 suspension- supposed to be firmer than 4-cylinder? 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 6 09-20-2003 02:33 PM
