2007 Camry Aftermarket Headunit...With PICS!!!
The thread above is for Valor TCR-07, which is an aftermarket Camry replacement. It looks like the OEM nav minus the backlit panel display. The buttons are backlit for night time, just not the text labels.
I believe for any GPS/Navigation system, plug n play in reference to wire harness should be relatively straight forward. However, for most GPS/Navigations, there is a GPS antenna that needs to be ran somewhere on the car or on the dash to help with positioning. So yes, you'll need to mount/run/apply an extra antenna for navigation units. I believe for the Valor TCR-07, the bluetooth module is contained within the device.
I'm looking at the Valor model, however the non-backlit text labels is a huge turn off for me. I was considering going aftermarket double din touchscreen unit, but I don't want to lose the bezel real estate. All of that blank space on the bezel might make it look rather ricey imho.
I've tossed around a few ideas regarding the bezel to help 'enhance' if I did decide to go with a double din unit. I was thinking of tossing in the V1 directional arrows although this may take some customizing with dremeling the aftermarket bezel for fitment, I still think it leaves a lot of blank space which is a look I don't want to go with.
Another option is to just go OEM nav unit from Toyota, granted not the best selection for the price, just at this point there isn't many options left.
Does anyone have a pic of a double din aftermarket nav unit with bezel replacement so I can gauge exactly how much blank space is located on it?
