metallic rattle in roof area - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2007, 02:17 AM   #1 (permalink)
07SEV6
View lklee's Photo Gallery
Gen6 metallic rattle in roof area
My 07 se makes a metallic sounding rattle in the roof when driving over uneven pavement. It makes no difference whether the sunroof is open or closed. It feels like there's a loose nut hitting the metal roof. I've read that others have experienced the same thing. Is this a known issue, and is there a fix? I will have the dealer look at it.
lklee is offline   Reply With Quote
Old 10-02-2007, 09:40 AM   #2 (permalink)
View wiccanferret's Photo Gallery
Good luck with that. Usually when the dealer tries to "fix" a rattle they end up making four more. What I would suggest is first getting some white lithium spray greasy and spraying down everything metal in there.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 10-02-2007, 10:02 AM   #3 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
There is a TSB out for a moonroof rattle which happens on the sides of the moonroof.
However, that does NOT sound metallic.
Due to a snow incident, my car had a brand new roof installed. And I lived with the EXACT same rattle which you describe. After lots of "research" into the problem with both the body shop (Toyota certified) and the dealer, we found this:
Take down the interior headliner. You will see 2-3 steel brackets/beams which go from left to right. These hold the roof up to its egg shape. Else it would not stay curved.
So each of these brackets is secured with bolts on both sides of the car just before the doors begin. In my case, on the right side, 2 of these bolts were not torqued properly. They were causing the metal-to-metal rattle anytime I drove over uneven pavement or bumps.
That right there is your solution. I saw it with my own eyes. If you explain this stuff to them, it will take a body shop 30 minutes or less to take it apart, tighten, and put back together.
I had my car fixed a couple of months back and the rattle has NOT returned ever since. I hope this helps you!
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 10-02-2007, 10:19 AM   #4 (permalink)
That's cool. That fix should be stickied...
07 Camry: Driver's side B-pillar rattle revisted proteus220 5th & 6th Generation (2002-2006 & 2007-2011) 7 06-01-2007 11:18 PM
passenger side dash rattle mrmatrix 5th & 6th Generation (2002-2006 & 2007-2011) 6 04-12-2007 09:09 AM
2007 Camry, B-Pillar driver side rattle - TSB? proteus220 5th & 6th Generation (2002-2006 & 2007-2011) 3 01-18-2007 10:29 AM
intermittent eng rattle rockhard 1st & 2nd Generation (1983–1986 & 1987-1991) 4 12-03-2006 01:46 AM
rattle from rear of 93 Supra cmwssc Supra Forum 2 06-28-2004 01:35 AM
