How many people torque their wheels? - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2007, 04:12 PM   #31 (permalink)
View V6 LVR's Photo Gallery
Gen6
Its interesting to see how many owners are not aware of the need to properly torque their wheels. It is criminal that many shops still use the impact wrench without the torque sticks. Make sure you demand they use the correct one. One shop I used , mentioned that they used the 80 lbs stick. Since there was only a 3 lbs difference from what is recommended I gave the go ahead. The sticks come in different colors and go up in 5 lb increments. Just make sure you verify everything. When they realize you up on all this torque stuff they will not pull any easy, fast ones. All this is so educational and serves to keep us save!! Happy motoring you all!
V6 LVR is offline   Reply With Quote
Old 11-07-2007, 07:27 PM   #32 (permalink)
sleekaman's Avatar
View sleekaman's Photo Gallery
so whats the torque ibs setting ?
So, for the 2007 Camrys (mind V6 XLE) what is the stud size, I see a variance for torque settings.
70-80ibs ? is a range.
or just 80ibs ?
http://www.tirerack.com/wheels/tech/...jsp?techid=107
http://www.discounttiredirect.com/di...08!NONE#toyota
I just recently bought a torque wrench was on sale for $40 Can., torqued my snow rims with 80ibs.
07 Camry V6 XLE (Family Cruiser)
03 Corolla LE (Daily Run-About)
85 Celica GT-S (Summer Fun Car)
http://sleekaman.webs.com/
sleekaman is offline   Reply With Quote
Old 11-07-2007, 07:34 PM   #33 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
or just 80ibs ?
The Tirerack's technician on this forum Tires and Wheels told me it's 77.
I have been using 80 just for easy to remember. So you are fine.
Old 11-07-2007, 07:41 PM   #34 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
or just 80ibs ?
What is ibs? Some Canadian thing??
76 ft.lbs (1,050 kg.cm) is the recommended torque no matter what your engine size.
Old 11-07-2007, 08:37 PM   #35 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Not ibs, it is Ft-lbs ( foot pounds) or Metric Nm (Newton Meters)
77 is a good torque for all OEM wheels, the Alloy OEM nuts have a cone seat and washer.
Otherwise most alloy wheels are around 65 to 69 Ft Lbs, and steel wheels, 90 Ft Lbs.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 11-07-2007, 09:38 PM   #36 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Not true at all, just another incorrect post.
Some vehicles require more than 100 ft/lbs. Not all OEM nuts have a cone seat and washer either.
Torque specifications should be checked for each vehicle.
2006 Camry LE Special Edition
Old 11-08-2007, 01:07 AM   #37 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
^ he speaks the truth -- though for my car, I use the manual specifications + 5 ft/lbs so it comes out to around 83-85 ft/lbs
remember, star pattern + go back to the 1st nut at the end to ensure it's completely snug!
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 11-08-2007, 09:51 PM   #38 (permalink)
sleekaman's Avatar
Canada Just testing you Njerald
me bad, thats cool that you caught my spelling error Njerald, I knew you would. After posting two web sites of reference you still think ibs is not lbs ? wow, you're very picky. As for "some Canadian thing" I'm not sure where thats going, but I'll leave that one alone.
Old 11-08-2007, 09:54 PM   #39 (permalink)
Here and there...
If you don't know about "some Canadian thing" then just ask a member here name Punks_Not_Dead5. He can tell you all about it!
Old 11-08-2007, 11:00 PM   #40 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
Originally Posted by LNGasMan View Post
Several hundred for a good brand like Snap-on or Mac Tools, less than $100 for a Craftsman. Don't get the $20 cheap ones from Harbor Freight.
I got a cheap one from Harbor Freight....works fine so far.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 11-08-2007, 11:22 PM   #41 (permalink)
View mcdawgg's Photo Gallery
My '07 owner's manual says 76 ft lbs.
mcdawgg is offline   Reply With Quote
Old 11-08-2007, 11:27 PM   #42 (permalink)
'07 XLE
Gen6
I think I've seen 76 ft lbs, now a number of times..............
Old 11-09-2007, 12:45 AM   #43 (permalink)
View krouchchocolate's Photo Gallery
if you get aftermarket rims, is it the same torque?
krouchchocolate is offline   Reply With Quote
Old 11-09-2007, 01:15 AM   #44 (permalink)
Here and there...
Yes, it's the same.
Old 11-09-2007, 10:01 AM   #45 (permalink)
View marc780's Photo Gallery
i usually dont bother, i have an electric impact wrench and it seems to torque the aluminum wheels about right - no wobbles or cracks in the wheels - its a lot of trouble cause i take the wheels off and on alot to check brakes etc.
If you torque the wheels you are torquing 20 times and if the wheels are about as tight as they are supposed to be its enough - not too tight or too loose.
I change wheels at work every day and imagine if i had to torque every single lug nut? We have the torque sticks but i usually dont bother using them. Even if you have an impact wrench many of them have adjustable settings so you set it one or two clicks down from tightest and just blip it on. No wheels fell off yet and ive done a thousand or two.
16" versus 17" wheels Fluxaholic 2nd Generation (2005+) 14 06-22-2007 10:15 AM
And you thought buying new wheels was fun... slvrAZtaco 2nd Generation (2005+) 12 03-23-2007 09:37 PM
On the dyno today for baseline... calypson 2nd Generation (2005+) 42 05-26-2006 08:55 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
