Can anyone show me a diagram/vid on where the vacume line is on a gen5 camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2007, 08:54 PM   #1 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
Gen5 Can anyone show me a diagram/vid on where the vacume line is on a gen5 camry?
....I want to seafoam it. I know the basic area of where it should be located, but there are alot of hoses in that area. lol
edit: forgot to mention its an I4
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 10-06-2007, 09:54 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
There aren't any in the online manual?
2006 Camry LE Special Edition
Old 10-06-2007, 11:14 PM   #3 (permalink)
The Connoisseur
CharmCityES's Avatar
www.camrymanuals.com
there is a brake booster line that runs from a rubber tube into a steel brake line right behind the engine block on typical 2az engines....disconnect this at the junction of the two tubes and dip the ubber tube into the bottle of seafoam, and it should suck the fluid into the engine, ad the car usues the braker booster system to convert vaccum from the engine into assiantance in the hydrulic brake system....be sure to use only 1/3 a bottle as specified on the box, and be sure to reconnect all lines and clean up after yourslef when done.
good luck.
The "Executive Sedan"
Old 10-07-2007, 01:02 AM   #4 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
I borrowed this image from TRD's cardomain page. I hope you don't mind.
Thats the hose I used to put seafoam in.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 10-07-2007, 09:25 AM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen5
thanks for the pic, did seafoaming it make it any faster, smother, etc..?
Old 10-07-2007, 11:04 AM   #6 (permalink)
TRD VVTi's Avatar
Gen5
I don't mind at all. You could have used the pic with the nice TRD oil and radiator caps though.
That isn't the optimum line to use when cleaning the intake though.
Oh well, I guess the OP didn't really want to know anyways...
Old 10-07-2007, 12:03 PM   #7 (permalink)
The Connoisseur
i've always used the brake booster line as reccomended by seafoam
its a direct enyr into the engine....any vaccum line is suitable tho, and you can even put it through the gastank as well
Old 10-07-2007, 12:09 PM   #8 (permalink)
TRD VVTi's Avatar
Sea Foam recommends using the brake booster line for the Camry?
Please post that information. I would really like to see it.
I can understand that the Sea Foam can says to use the brake booster line. That's something that nearly every vehicle has in the same location. It's a generic or general recommendation that isn't application/vehicle specific.
There are better ways to get Sea Foam to clean the intake other than using a vacuum port at the base of the intake.
I've gone over this before in the Sea Foam post just recently...
EDIT: If Sea Foam says to use the brake booster vacuum line, how would you do that on a vehicle that has hydra boost?
Old 10-07-2007, 04:40 PM   #9 (permalink)
The Connoisseur
seafoam reccomends using the brake booster line in general....i know on camry models were not supposed to induce seafoam into the throttle body, and it is reccomeneded that it ios induced somewhere after the throttle body
theres a few vaccum lines you can use...i just choose the brake booster for ease
Old 10-07-2007, 05:01 PM   #10 (permalink)
TRD VVTi's Avatar
I will use the vacuum hose for the vacuum switching valve.
It makes much more sense. Instead of cleaner being sucked into the base of the intake it will be pulled into the very top of the intake. That will ensure that all the intake runners get cleaned.
To me that makes a lot more sense.
Old 10-07-2007, 08:25 PM   #11 (permalink)
The Connoisseur
thats a good idea....ill have to use the VSV next time i seafoam....i just used the brake booster line as thats what the seafoam box reccomended
thanks TRD...learn something new every day
Old 10-07-2007, 09:30 PM   #12 (permalink)
TRD VVTi's Avatar
Gen5
^ You're welcome you sexy man.
I'm kidding of course. I'm not infected with the ghey.
Old 10-08-2007, 05:34 PM   #13 (permalink)
View sundarpn's Photo Gallery
TRD,
any picture of the vac line you are talking about on the vsv?
I would want to use that as your explanation made a lot of sense.
also whats the talk about the check engine light coming on after using Seafom? I'll get a minor stroke if that happens in my 2002 XLE I-4.
(Oh well I get my state inspection done then do seafom just in case)
btw, were to get a deal on a can of seafom. walmart did not have it.
sundarpn is offline   Reply With Quote
Old 10-08-2007, 08:52 PM   #14 (permalink)
TRD VVTi's Avatar
Originally Posted by sundarpn View Post
TRD,
The VSV vacuum line goes from the VSV to the bottom of the throttle body. The VSV is just behind the MAF. No, I don't have a pic.
Do the inspection first. The check engine light may come on (it will if you add the cleaner properly) for a missfire, rich condition, etc... After you're done with the cleaner just drive the car for a few miles. Then remove the negative battery cable for a couple of minutes to reset the ECU/PCM.
If you do the service and then reset the ECU, you will have to put many miles on the car before all the self tests can be performed and the ECU shows all the systems ready.
EDIT: For pics, just check the online manual.
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
Toyota Confirms Lexus LS, Camry for 2006 Detroit Auto Show EKam Toyota News 15 12-30-2005 09:30 AM
JUST WON MY 1ST SHOW......WITH MY CAMRY!!!! mean_green Camry & Solara Lounge 9 08-06-2002 01:30 PM
